Hi! Need a bit of help to choose which cloud rendering service to use... I've read about a few but have no previous experience on this. I have a pretty good upload speed, I can upload at several Megabytes per second, usually a 1 GB file takes just a few seconds to upload, of course if the system on the other side have a good server too. I'm using big maps, so have a fast upload is important.
Does it makes a difference if the cloud is no in the US where I'm located? In terms of up,pad download speeds...
Also, need to do pre passes for the lightning, some are just flying cameras so not a big issue, but a few shots I have animation of objects, so need to use the prepass for animation, this need to be supported by the cloud system?
Ideally would be a system where it is just a plugin in the software and no need of complicated operations that can make it fail happens... Like for example I was reading the documents for Ranch Computing, and find it a bit cumbersome on what you have to do to do the passes....
Any recommendations and ideas or words about your experience with certain service will be of great help
Thanks.
Thanks.
