Originally posted by Dave_Wortley
View Post
Determining correct falloff
Originally posted by Wobi View PostHey Rens,
I didn't mean to offend you. So no need to feel sorry. Anyway, what I think would be nice to have would be something like this:
[ATTACH=CONFIG]23937[/ATTACH]
It's a mix of setting artist-friendly 0-Degree-Color and the UI of the Arch&Design-Material. So you can visualize the curve right away, while still not having to work with these unfriendly output-curve of max.
Of course, this is just a 5-Minute PhotoShop-UI and lacks many other aspects, e.g. setting n+k values. But this woud speed up working with these curves and color values for me.
Maybe something like this could be implemented with a mix of scripted texturemap, OSL-Shader and Dotnet-UI... but well... I'm drifting away...
PS: the values in there don't make sense... just a photoshop-quickie as I said...
I too, feel stupid reading this thread but I'll make sure to link to viscorbels post and this thread when explaining in a later lesson.
Cheers guys for clearing all this up!admin@masteringcgi.com.au
Mastering CGI
CGSociety Folio
CREAM Studios
Mastering V-Ray Thread
Originally posted by Deflaminis View PostAnyone feeling benevolent enough to do a post here detailing the conclusion and best methodology? I'm ashamed to admit I'm not sure after re-reading multiple times.
There doesn't seem to be one ideal one just yet, the osl stuff will let you use refractive index data *but* it's not the most intuitive to tweak with and the data will only give you matches for one specific sample of a metal which may not match yours - you won't get artistic control afterwards. The falloff / mapped gradient stuff will give you more tweakability afterwards but it means a bit more setup. I reckon someone'll probably throw together a better OSL map that has all the bits combined similar to that ui concept posted.
I'm talking to Autodesk to see if we can't get a linear Falloff map, but well, don't hold your breath!Maxscript made easy....
davewortley.wordpress.com
Follow me here:
facebook.com/MaxMadeEasy
If you don't MaxScript, then have a look at my blog and learn how easy and powerful it can be.
Originally posted by joconnell View PostThere doesn't seem to be one ideal one just yet, the osl stuff will let you use refractive index data *but* it's not the most intuitive to tweak with and the data will only give you matches for one specific sample of a metal which may not match yours - you won't get artistic control afterwards. The falloff / mapped gradient stuff will give you more tweakability afterwards but it means a bit more setup. I reckon someone'll probably throw together a better OSL map that has all the bits combined similar to that ui concept posted.
Originally posted by Rens View PostHm yeah, it is slightly towards 0 degrees:
[ATTACH=CONFIG]23892[/ATTACH]
Left VrayBlend with Falloff as mask, VRayMtl for both, one diffuse, one reflective.
Right VRayMtl with Refl.
All at IOR 1,6.
I doubt that's because of the cos/linear issue though, maybe some energy preservation difference, or a slightly different equation.
-Eugenio
Originally posted by dubcat View PostOps, sorry about that. Try againBest regards,
Jackie Teh
3ds Max 2023, V-Ray 7 [7.00.05 build 32980]
AMD Ryzen 9 7950X 16-Core Processor@4.50 GHz | 64GB RAM | Nvidia RTX 4090
Website: https://www.sporadicstudio.com
Email: info@sporadicstudio.com
YouTube: https://www.youtube.com/c/SporadicStudio
