Request- Film Response Curves (Comparing Octane to V-Ray)
  • #16
    Originally posted by Dave_Wortley View Post
    Colour workflows and gamut are just blackholes of mashing information that could really do some with clarifaction, but no-one seems capable of deciding which is best.
    I'm not the right person for this either
    • #17
      If those could be converted into LUT's it would be a tremendous help, people are going to love it.
      Another question I have is- Does V-Ray Calculate other objects specular highlights into the reflection pass properly?
      I'm slowly piece by piece matching V-Ray to Octane but one thing I can't seem to figure out is this effect of V-Rays reflections being much darker and I believe it's because it's not adding the speculars of other objects into the calculation.
      If you look at the octane image you can see the reflections are very bright and match the brightness of the highlight on the cylinder next to it whereas V-Rays secondary reflections look like they aren't accounting for the added specular.
      Check the image below, some clarification would be greatly appreciated!
      admin@masteringcgi.com.au
      Mastering CGI
      CGSociety Folio
      CREAM Studios
      Mastering V-Ray Thread
      • #18
        Yes, they are calculated correctly. However, the "max ray intensity" option and disabled "reflective GI caustics" option may suppress bright highlights in reflections in order to avoid speckles and fireflies.
        • #19
          Feeling very stupid, literally just turned off reflective GI caustics! Thanks!
          Mastering CGI
          CGSociety Folio
          CREAM Studios
          • #20
            Ok, good to know. Actually, now that we have the max ray intensity option, it's probably safe to enable GI caustics by default... I'll have to think about it a bit.
            • #21
              We can write a tool that converts these to LUT profiles, if you think this will be useful.
              Yes, YES, a thousand times YES!!!
              I've stumbled over those response curve files a while ago and had no idea how to put them to use... I've asked in several forums and no one even replied. It would be awesome if these data would finally be available in a format that could be used in Max, AfterEffects, Photoshop, etc.
              • #22
                Triple that!
                I'm so looking for a way to get response curves in AFX!
                For the moment I'm stuck with Ps using arion fx but I'm so looking forward for a solution in AFX!
                Be able to see then in VfB and them re-apply them in afx would be a game changer!
                Stan
                3LP Team
                • #23
                  Vlado, if they can be converted to
                  CUBE, 3DL or LOOK files then we can use these in Photoshop (and probably all other compositing softwares) too for consistency
                  Maxscript made easy....
                  davewortley.wordpress.com
                  Follow me here:
                  facebook.com/MaxMadeEasy
                  If you don't MaxScript, then have a look at my blog and learn how easy and powerful it can be.
                  • #24
                    Enabling GI caustics still creates a lot of GI noise in a variety of scenes. Indeed, it often does look better, but is there a solution to this?
                    • #25
                      By the way, are both GI caustics enabled by default in RT GPU?
                      Cheers Stan
                      3LP Team
                      • #26
                        Only refractive caustics are enabled by default.
                        • #27
                          Hey Vlado
                          Here is another wip as I work through my "Octane Look in V-Ray"
                          I have a new found respect for V-Ray. I guess sometimes it takes rethinking things to come up with a solution but once again, the biggest hurdle is the response curves.
                          The V-Ray Render is using the Motiva Exposure plugin for V-Ray but the response curve doesn't look indentical to Octanes. The highlights are blowing out a little more and the colors are saturating a bit differently.
                          It's not a massive difference but my goal was to make things near exact so that I don't have to teach people a new render engine.
                          On top of that, once again, Gamma is another hurdle. I can adjust the gamma in realtime in octane. With this response curve I need to double it up. In V-Ray I'm not getting things exact because I'm using a custom curve.
                          So far there has been huge interest in getting these curves into V-Ray and I think for the amount of impact they can have on the overall realism, it's going to be a great addition.
                          I never thought I'd get V-Ray looking the same but I'm so close and It's pretty exciting!
                          Mastering CGI
                          CGSociety Folio
                          CREAM Studios
                          • #28
                            Why would you ever need to adjust the gamma?
                            • #29
                              Some of the response curves have gamma baked in. So you apply them and the render goes much darker. you need to correct for that. I can adjust the gamma using color mapping but it doesn't work with this colimo plugin
                              Mastering CGI
                              CGSociety Folio
                              CREAM Studios
                              • #30
                                (I often experiment with completely random gamma numbers inside octane when swapping to different response curves also. It's totally dependent on the lighting of the scene or the subject material but either way, having that extra layer of creative control can definitely be the difference between fake and real)
                                Mastering CGI
                                CGSociety Folio
                                CREAM Studios
