Weathered material help
  • #16
    I think what happened is when the blend material was written, it didn't have full maxscript access originally so the options had to be kind of stuck on, the dup slots are a side effect of this, don't worry about them aside from untidiness.
    • #17
      The complex fresnel I'm using is the free plugin from Siger. Works quite well and easy to set up. Just pop it in the reflection slot and disable fresnel on the mat.
      sigertexmap-complexfresnel
      Originally posted by Streetwise View Post
      2) I'm curious to know what your "complex fresnal" map looks like? It appears to be a fall-off of some sort, or I saw something about VRayOSLTex, but I'm unsure how to create what I need for that.
      [ATTACH=CONFIG]28387[/ATTACH]
      • #18
        Excellent! Thank you so much! I see Siger has a free scratches plugin too. That's great. Again. Thank you.
        David Anderson
        www.DavidAnderson.tv
        Software:
        Windows 10 Pro
        3ds Max 2024.2.1 Update
        V-Ray GPU 6 Update 2.1
        Hardware:
        Puget Systems
        TRX40 EATX
        AMD Ryzen Threadripper 3970X 32-Core 3.69GHz
        2X NVIDIA GeForce RTX 3090
        128GB RAM
