I think what happened is when the blend material was written, it didn't have full maxscript access originally so the options had to be kind of stuck on, the dup slots are a side effect of this, don't worry about them aside from untidiness.
Weathered material help
The complex fresnel I'm using is the free plugin from Siger. Works quite well and easy to set up. Just pop it in the reflection slot and disable fresnel on the mat.
sigertexmap-complexfresnel
Originally posted by Streetwise View Post2) I'm curious to know what your "complex fresnal" map looks like? It appears to be a fall-off of some sort, or I saw something about VRayOSLTex, but I'm unsure how to create what I need for that.
[ATTACH=CONFIG]28387[/ATTACH]
Originally posted by viscorbel View PostThe complex fresnel I'm using is the free plugin from Siger. Works quite well and easy to set up. Just pop it in the reflection slot and disable fresnel on the mat.David Anderson
www.DavidAnderson.tv
Software:
Windows 10 Pro
3ds Max 2023.3 Update
V-Ray GPU 6 Update 1
Hardware:
Puget Systems TRX40 EATX
AMD Ryzen Threadripper 3970X 32-Core 3.69GHz
2X NVIDIA GeForce RTX 3090
128GB RAM
