Have here a problem actually , for some reason when i import a VDB file from houdini to VRayVolumeGrid - it is empty. Though i'm pretty sure it should be fine , as it weights about 10mb , and in houdini it previews fine. That should be some settings in VRayVolumeGrid ? In input size it is empty and looks like a point for some reason.
Yeah looks like there are. Well there is zdepth anyway
only if you render in geometry mode which is very slow to get the same look
i suppose this is to be expected and i ended up doing a zdepth in a seperated pass with low bounce settings to get around this
Yeah looks like for now this is the only way.
Here you can check new update , this is straight render. On the background for cirrus clouds i used HDRI from noEmotion guys (thanks for that one!)
higher res : https://www.dropbox.com/s/ewjbft9z36...est_2.jpg?dl=0
Still not looking real though , it is hard to simulate nature !
