Sorry for the lack of updates, busy busy.
No, I've measured the values from 1, 2 and 3 panes of glass and fitted reflection and refraction curves to match them. When using more than one face/side of geo the calculations won't work anymore and you'd get unexpected results. : )
The reason for this is that it's pretty hard to get values right if you're using only a plane as your geo for speed. Raytracing two or three actual panes of glass would be much slower.
IOR out would be the IOR of air usually (outside of the glass). You could for example simulate window glass under water (IOR 1.333) as well if you'd ever want to... probably not though hehe. Setting both to 1.55 would effectively cancel out any reflection.
Hope this helps!
Originally posted by snivlem
View Post
Hope this helps!
