Originally posted by Mennovandijk
View Post
Production render in IPR mode
Patrick Macdonald
Lighting TD : http://reformstudios.com Developer of "Mission Control", the spreadsheet editor for 3ds Max http://reformstudios.com/mission-control-for-3ds-max/
It's actually trivial to create more update callbacks manually (i did so myself for an early version, only very few lines of maxscript), but it's better to wait for Vlado to finish off what course he's on already, to avoid needless performance degradation.
It's been coded for 2017 first precisely because of the new messaging system that Max version has, so let's see how that performs (overall, for me, quite superbly. in one lookdev session i saved the vast majority of my cursor movement, shortening the session massively, and not getting RSI from clicks and mouse presses.Never a slowdown, hiccup, crash. At most i had to manually stop and restart the ipr when i wanted to change the render settings.).Lele
emanuele.lecchi@chaos.com
Disclaimer:
Would be nice if render settings could be changed on the fly too. The less restarts, the betterEspecially in bigger scenes that can take two or three dozens of seconds to translate.
Most of the render settings, except for a few in system rollout, shouldn't really require complete re-translation of scene. And even if they do, it would still make more sense for IPR to just re-translate entire scene to make the change happen, rather than silently fail.
Hey Lele,
I'm curious about the new callback mechanism in 2017. I can't see any documentation about in in the 2017 docs. Is this simply under the hood, only SDK or is it also exposed to maxscript?
Cheers
p.Patrick Macdonald
Cheers
p.
It came about with the reviled ART renderer, and the physical material, as a global push to make the messaging between app and renderer more universal and modern.Lele
Disclaimer:
Originally posted by Mennovandijk View PostWhat is the difference with this and using vray progressive render in the 'active shade' viewport?
VladoI only act like I know everything, Rogers.
Originally posted by Recon442 View PostWould be nice if render settings could be changed on the fly too. The less restarts, the betterEspecially in bigger scenes that can take two or three dozens of seconds to translate. Most of the render settings, except for a few in system rollout, shouldn't really require complete re-translation of scene. And even if they do, it would still make more sense for IPR to just re-translate entire scene to make the change happen, rather than silently fail.
That's a killer feature for me! We almost decided to look into c* renderer for this specific feature here at our studio.. But not anymore! =D.
Is it planned to be implemented in the next SP (if there is any SP before V 4.0? ) or it is too early to talk about that.
Simply, I love to put pixels together! Sounds easy right : ))
Sketchbook-1 /Sketchbook-2 / Behance / Facebook
Originally posted by Nicinus View PostDoes this effectively replace the Vray RT CPU mode?
If so, I assume this could also mean speedier development of Vray RT GPU as the focus is now clear for that team.
Originally posted by AndresAhumada View PostWhen is the release date?
Best regards
