I must confess I'm rather shocked at the way this is implemented. I hope this is meant as a temporary sollution. There is allready an interface that pops up when typing the command in the listener, but why is this not a part of the vray proxy objects UI? Or part of the regular max export/import?
I have a rather large project totaling approx 5 million faces.
There are two options;
1. Optimise the models to within an inch of its life or
2. Utilise the vrmesh facitlity.
In your opinion, would the vrmesh facility be able to do the job ?
I have found that models brought in are not aligned correctly and the materials have to be reassigned. Neither are a major problem but, are there any further irregularities that may affect the process ?
I did not had any other problem then you allready say.
namely mat + position.
position is very easy: the vray mesh hold its original 0 point, so just use your move tool and set x and y to 0.
for mat, just pick the ones out of your org. file in mat editor and reapply to your vray mesh, it contains all the parameters so no sweat.
