Verdict on Max 2018?
  • #16
    Originally posted by leehumphries View Post
    following on from this post on Max 2018. i actually like 2018 and although i have had a few crashes i don't believe its down to max for once. Mine was issues keeping IPR always on and updating floor generator materials. Which i should of probably shut IPR down before tweaking stuff. I used 2017 for the past year and found so many random crashes became a pain to work safely with.
    2018 does have a few little issues with scene explorer but only regarding some shortcuts.
    Any IPR could have problem when you use some 3dsMax maps.
    It is because 3dsMax maps are not completely thread safe.
    It happens for Arnold IPR, too.
    • #17
      anthonyh selection brackets - cant you when object selected just press letter 'J' on keyboard to turn selction brackets on / off. If that is what you meant
      • #18
        @leehumpries - oh nice, didn`t know that. now to condition my brain to remember. many thanks.
        anthonyh
        • #19
          Originally posted by gandhics View Post
          BTW, "as for 2018 the forced double selection issue for entry boxes/drop down menus is really starting to annoy.".
          What does it mean? Any step to reproduce? Did you have 2018.1?
          If possible I'd like to know a little more about this too.
          Thanks for all the replies so far!
          http://www.glass-canvas.co.uk
          • #20
            double selection issue:
            i did another post about this i think. what you do is have render settings window open on say vray tab. now click in the viewport to make it active(or on an object whatever). now go to select a drop down menu or input box eg the progressive/bucket menu or noise threshold or other and it doesn`t properly register the click, the menu will ping off and the input box won`t register until you click again. i`ve noticed this happening elsewhere too but i can`t remember where offhand. seems totally repeatable for me at least.
            • #21
              I would like to know more about this. Can you tell me how we can reproduce the issue here? Do you still have the crash dump?
              • #22
                Can you be more specific about the Floor generator + IRP issues ?
                Peter Matanov
                Chaos
                • #23
                  vlado matanov i think it was my stupid fault with IPR and floor generator. I tried deleting a bitmap in slate editor that was already linked to an object and it crashed. I realised it used to do it on previous versions of max, so not necessarily IPR. I do get the odd errors in vray messages when using IPR. I have literally only just started using it and its such a great tool i will keep updating if i find anything strage going on. One thing i noticed when using railclone and forest with IPR on the actualy pointcloud data or geo for forest / railcone dissapears from the viewport view. When using normal progressive render it doesnt.
                  • #24
                    We (Chaos and iToo) are aware of the viewport disappearing thing and it will be addressed soon.
                    Peter Matanov
                    Chaos
                    • #25
                      vlado where do i get the dump file from to send over when i get a crash ?
                      Still getting crashes when IPR open with railclone now.and milti texture. May not be vray related tho.
                      I changed from texture to object in multi texture with IPR on running and crashed
                      • #26
                        In %temp% folder - 3dsmax_minidump.dmp and/or VRay.dmp. Of course it will be best if you send us the scene(s).
                        Peter Matanov
                        Chaos
                        • #27
                          So is 2018 any good now? How does it stack to 2016 in terms of stability and bugs? I'm contemplating transitioning but I'm very cautious still.
                          Aleksandar Mitov
                          www.renarvisuals.com
                          office@renarvisuals.com
                          AMD Ryzen 9 9950X 16-core
                          96GB DDR5
                          • #28
                            It does include Stingray now. That is my main reason to install it. The scene transfer (even with V-Ray Materials) is pretty easy.
                            Olaf Bendfeldt
                            3D-Artist
                            dimension3+
                            • #29
                              Crashes constantly with Railclone and IPR. It's really hard to get any work done in its current state. Hopefully, they fix these issues.
                              • #30
                                I installed it for Stingray, it is easy as hell getting a VR experience, instead of walking through Unreal Engine process. And for free...why not!
