Verdict on Max 2018?
  • #46
    Can anyone verify what their 2018 "About Max" shows after update? My "About Max" shows
    Product Version:
    2018Update
    20.0 - 20.1.0.1452
    AutoDesk site has 2018.1 Update available but about Max uses somewhat different nomenclature (shown above)
    It appears that I may have the most current update but it's somewhat unclear and so I'm not 100% sure.
    mark f.
    openrangeimaging.com
    Max 2025.2 | Vray 6 update 2.1 | Win 10
    Core i7 6950 | GeForce RTX 2060 | 64 G RAM
    • #47
      Originally posted by hoppergrass View Post
      "However there's one thing that I noticed within the first 30 mins. You can't right click on a toolbar and delete buttons, rename them or edit the script.
      Yes, this is logged and listed as critical. Very annoying issue and the devs are already addressing it.
      OPEN_RANGE -
      The initial release of 2018 was 20.0.0.966 and Update 1 is 20.0 - 20.1.0.1452. So I can confirm you do have Update1 installed currently.
      Best Regards,
      AJ (Alfred)
      • #48
        Thanks AJ!
        mark f.
        • #49
          Is anyone else having issues with Max/Vray hanging around for a while on render end?
          Check out my (rarely updated) blog @ http://macviz.blogspot.co.uk/
          www.robertslimbrick.com
          Cache nothing. Brute force everything.
          • #50
            Why the hell is the update to 2018.1 taking 45mins to install? It hangs at "gathering required information" for 40 minutes. Seriously, **** *** ADSK.
            • #51
              Alright,
              next journey in this big pile of crap they call Max 2018. I can't render via backburner. The job gets sent to the client, Max opens and crashes immidiately. The error just says "No response".
              I guess it is related to the problem I had before, but I have already installed Update 1.
              • #52
                By the way, on the clients with no graphic cards, Max still crashes on startup. Despite Update 1.
                • #53
                  Crashes, crashes everywhere.
                  Honestly, back to 2017. Thanks, Autodesk.
                  • #54
                    Sorry...but just to know... as "no graphic cards" do you mean literally or a recent graphic card?
                    I have 3 slaves with Matrox G200eV that is something like a simple videocard to switch ON a monitor...I hope 3dsmax 2018 will consider those as graphic cards
                    • #55
                      No dedicated GPU at all. Just some internal Intel graphics chip. These are purely render slaves, in a rack mount housing from Chenbro.
                      • #56
                        did they set viewport driver to Nitrous Software?
                        • #57
                          Tried all graphics modes, including Nitrous Software. No matter what I choose, it crashes. Also disabled welcome screen.
                          • #58
                            Does anyone have problems resizing the d@mn Scene Explorer window/panel in 2018? I can't seem to do it. I have update 2 installed. I can't believe this glaring obvious problem can make it into the finished final product, not to mention after TWO updates.
                            Aleksandar Mitov
                            www.renarvisuals.com
                            office@renarvisuals.com
                            AMD Ryzen 9 9950X 16-core
                            96GB DDR5
                            • #59
                              It can't be worse than 2017, oh yeah I forgot, it is Autodesk. 2017 crashes on me 2-3 times a day and that is a lot better than when I first started using it. I am content with 2-3 crashes a day, which tells you how bad things have gotten. I am afraid to move to 2018; I don't want to start over.
                              Bobby Parker
                              www.bobby-parker.com
                              e-mail: info@bobby-parker.com
                              phone: 2188206812
                              My current hardware setup:
                              • Ryzen 9 5900x CPU
                              • 128gb Vengeance RGB Pro RAM
                              • NVIDIA GeForce RTX 4090 X2
                              • ​Windows 11 Pro
                              • #60
                                Hi Bobby
                                From our experience 2018 is a lot more stable than 2017. I would recommend updating
