Verdict on Max 2018?
  • #76
    For camera, could u guy try this on listener to see if it make things any better?
    Default is false. So if you don't see any difference, set back to false.
    NitrousGraphicsManager.HardwareHitTestEnabled = true
    • #77
      Originally posted by TutanMark View Post
      Hi Bruce, what kind of camera selection bug?
      The problem I was referring to is when you select the camera head the target gets selected also. That means it's impossible to move the camera while leaving the target stationary. The workaround (from a mouse selection) is to select the target first and then right click a quad menu to select the camera head. Stupid. As mentioned - it's extremely frustrating to get an "update" that breaks a function that worked previously.
      • #78
        Plus one.That is very annoying. The other workaround is, after selecting camera and now by default getting camera + target selected, to take the previously unneeded step of alt click the target to de select.
        mark f.
        openrangeimaging.com
        Max 2025.2 | Vray 6 update 2.1 | Win 10
        Core i7 6950 | GeForce RTX 2060 | 64 G RAM
        • #79
          interestingly it doesn't have this issue with standard cameras, only physical cameras and even worse if you use a physical camera with no target where you cant select the camera at all
          • #80
            I just tried to use 2018.2 on a project here involving just simple modeling. What a pile of garbage... It crashes, I'm not exaggerating, every 5 f*cking minutes on simple operations like adding/moving modifiers and even selecting stuff. Seriously, f*ck this sh*t! I saved my project file down to version 2016 and continued working on it in Max 2016 and I haven't had a single crash or a problem since then. This is second Max version in a row that I've paid for and won't use (thanks, Autodesk... not!). Sadly, it looks like the only thing increasing along with the upgrade prices is the monumental lack of competence and commitment to their clients. The price of Max since version 2016 should be decreasing with each newer version, not increasing. The fact that they can't fix a simple camera selection bug for 2-3 years now is more than telling. I I'm fuming right now.
            Aleksandar Mitov
            www.renarvisuals.com
            office@renarvisuals.com
            AMD Ryzen 9 9950X 16-core
            96GB DDR5
            • #81
              So how long can we hang on to 2016 before it gets removed from subscription? When 2020 gets released, right?
              • #82
                The physical camera selection issue was fixed in Update 3. Give that a shot and let us know if it's fixed for you.
                -Chippy
                • #83
                  Likely you have some conflict with drivers, plugins, OS or other issue? This surely isn't the norm for most users upgrading. We've just recently brought all our machines up to speed without any major problems. Have you taken any time to trouble shoot the issue?
                  • #84
                    I have 2018 version 20.0 - 20.3.0.3149 (from the About 3DS Max - Help Menu). The physical camera selection bug remains. Select physical camera and it, still, also simultaneously selects the camera target. Not sure why you think it has been fixed in Update 3?
                    mark f.
                    • #85
                      Half the guys in the office here crash when launching so we're stuck with 2016 (skipped 2017). We updated to update 3 and have installed latest video card drivers.
                      • #86
                        Just a note. 2018.3 is out.
                        Bobby Parker
                        www.bobby-parker.com
                        e-mail: info@bobby-parker.com
                        phone: 2188206812
                        My current hardware setup:
                        • Ryzen 9 5900x CPU
                        • 128gb Vengeance RGB Pro RAM
                        • NVIDIA GeForce RTX 4090 X2
                        • ​Windows 11 Pro
                        • #87
                          There`s also a 2016.5 but there`s very little in the notes to make it worth it. I wonder what else they`ve broken though ?
                          • #88
                            OMG, I am so sorry. We had fixed it internally. Thought it made it into Update 3. Apologizes for the confusion. Will follow up when it could be available in a possible update. Believe me, I understand the frustration.
                            -Chippy
                            • #89
                              so, is there any reason to update to 18 from 17? not had any major headaches with 17 so tempted to stick with what i know...
                              when the going gets weird, the weird turn pro - hunter s. thompson
                              • #90
                                ?Don?t fix something that already works? may apply. I don?t know what new features are in 18 that you might benefit from. You might be able to find a list or comparison or ?new in 18? from autodesk.
                                FWIW many found 17 to be very, even extremely, problematic in various ways. 18 seems generally to have been an improvement over 17 with some bugs fixed.
                                The updates seem to break things that always worked in the past. Paying significant $ to subscribe to a product that seems to break basic functions on each new version has caused a lot of frustration for very many users. This seems like a fairly recent development starting with especially 17. Prior to that each successive new version always had it?s critics, but nowhere near the level of widespread problems that have been in play since 17.
                                My two cents. best of luck.
                                this post is turning all the apostrophe and quotation symbols into ? Marks. Just discussing 17 causes bugs
                                mark f.
