Help Topic: VRayBlendMtl - How to properly blend specular layers.
    Thank you very much for this.
    I think I will use this method until Chaos Group fixes this huge problem with a proper VrayCoatMtl
    It would be good to hear from Chaos Group - freed-back regarding the coat material. May I please ask if someone from Chaos Group can comment on the subject of a coat material? it will help release my anxiety to know that a solution is on its way.
    Thank you all for being so helpful
    Steve ~
      I did some research and found that the falloff map is from the scanline render days when they used a falloff in the reflection slot. That's like, 15 year old tech....
      I hope Vray can make their own coat material soon.
        Well, the actual math for it is about 200 years old, it's just not implemented correctly in the Falloff map.
        Rens Heeren
        Generalist
        WEBSITE - IMDB - LINKEDIN - OSL SHADERS
