Vray Displacement on Carpet with breaks
  • Vray Displacement on Carpet with breaks
    Still have not figured out why I am getting sudden breaks in displacement on some objects just like the one on the enclosed image
    Both the floor and the grass are simple 2D polylines extruded up and mapped. I am using 2D VrayDisplacement. Default MAX displacement is turned OFF. I have tried Tight Bounds option both checked and unchecked - no difference. It is not a smoothing issue either, I have applied Smooth modifier to remove all Smoothing groups before Displacement. Adaptive Subdivision -1/+1 Threshold 0.1. Any ideas ?
    This is with Fixed Rate: 1.
    Clearly visible.
      if you're not already, try using a standard material for the color, and select Faceted.. that has a tendency to clear up a lot of my various Displacement oddities.
      Dave Buchhofer. // Vsaiwrk
        Cool Tip !
        It really did the thing. Thanks alot Dbuchhofer.
          looks like a normal problem.?!
          S.wolf
            Using box mapping also seems to fix that particular error, even if mapping a plane.
            Richard De Souza
            www.themanoeuvre.com
              richard is right..
              had the same plane yesterday..
              regards
              S.Wolf
