chromatic aberration with VRay
  • #16
    With the suggestions here, several years ago about getting a DSL and playing around, I found how much money you have to spend to get a lens that doesn't have these issues. I stopped using chromatic aberration a year ago and I don't think I have missed it.
    Bobby Parker
    www.bobby-parker.com
    e-mail: info@bobby-parker.com
    phone: 2188206812
    My current hardware setup:
    • Ryzen 9 5900x CPU
    • 128gb Vengeance RGB Pro RAM
    • NVIDIA GeForce RTX 4090 X2
    • ​Windows 11 Pro
    • #17
      Different strokes! For nearly every vfx shot I do there's some lens vignette, warp and chroma added to all our cg renders to mimic the properties of the lens that shot it - the imperfections are a big part of what makes our stuff feel real!
      • #18
        I do the vignette... I might put other things back in
        Bobby Parker
        phone: 2188206812
        • Ryzen 9 5900x CPU
        • ​Windows 11 Pro
        • #19
          so that old thing got dug out. I now realised - forgot to post the shader I was using: single plane in front of camera, additive vray blend mtl with 3 refractive lyers (refraction colour red/blue/green, cyan/yellow/magenta or whatever else fitting a+b+c=1.0) and ior of 0.097, 1.000 and 1.003 (or similar to control the strength of aberration.
          Marcin Piotrowski
          youtube
          CGI OCIO config 04
          • #20
            How are you guys adding it in post? I was using a plugin, in PS, but it adds a lot of blur.
            Bobby Parker
            phone: 2188206812
            • Ryzen 9 5900x CPU
            • ​Windows 11 Pro
            • #21
              photoshop is enough. but it is blur of sort. easy to overdo it.
              Marcin Piotrowski
              youtube
              CGI OCIO config 04
              • #22
                The software used is CINEMA 4D [Octane render?], but there is an interesting demo by Mr.Jeremy Cox.
                https://youtu.be/y8mKtNCq5CI?t=1269
                OakCorp Japan - Yuji Yamauchi
                oakcorp.net
                v-ray.jp
                • #23
                  Looks good! One of our interns also did an experiment with raytracing a real camera system; some results are below. We still haven't decided if we want to put this into V-Ray officially or just dump it on Github.
                  Did this ever get beyond the state of an experiment? Would something like this still work with V-Ray 6?
                  • #24
                    I pay a lot of money for lenses that don't have this issue . I never really understood adding it into an image unless you want to mimic an old camera.
                    Bobby Parker
                    phone: 2188206812
                    • Ryzen 9 5900x CPU
                    • ​Windows 11 Pro
                    • #25
                      We would love something like this in Vray, even if it means heavier renders when using it. Have a look at what it's possible in blender right now - https://www.blendermarket.com/produc...ack-v1?ref=586
                      Also for Arnold - https://lentil.xyz/
                      • #26
                        There are no lenses that do not have any amount of chromatic aberration. You will get CA with any lens, no matter how expensive, in certain conditions.
                        • #27
                          Yes, but will you see it in better lenses?
                          Bobby Parker
                          phone: 2188206812
                          • Ryzen 9 5900x CPU
                          • ​Windows 11 Pro
                          • #28
                            Yes, depending on the scenario. You will get CA with perfect lenses, too. Especially on high-contrast edges like a dark window frame against a bright background behind the window etc.
                            The amount of CA will get smaller with better lenses, but it will still be visible, mostly towards to corners of an image.
                            • #29
                              And most cinematographers specifically eschew the more perfect lenses, opting for older lenses with more flaws because they give the image more character.
                              • #30
                                this thing looks spectacular.
                                anyone with camera shader experience in VRay? is CA possible with it?
                                Marcin Piotrowski
                                youtube
                                CGI OCIO config 04
