This happens periodically, but once is too many. My VRay seems to go on strike and it stops working.
Dead VFB
Dead VFB
Bobby Parker
www.bobby-parker.com
e-mail: info@bobby-parker.com
phone: 2188206812
- 128gb Vengeance RGB Pro RAM
- NVIDIA GeForce RTX 4090
- Windows 11 Pro
Tags: None
Try turning off displacement from Global Switches and disabling any scattered object from rendering. RAM filling up like that points to loading stuff like geometry into memory before starting rendering. I've had this happen on a few occasions and AFAIK it was always bugged geometry with displacement or a botched scattering or Particle Flow operation.
BTW, what's up with the 2 minute startup time of Max? You might want to check that out. I would tear my hair out if I had to wait that long each launch. For reference mine takes just 15-20 sec. I hope you are not running your OS and apps off of an HDD (the old magnetic disks).Last edited by Alex_M; 28-11-2018, 06:23 PM.Max 2023.2.2 + Vray 6 Update 2.1 ( 6.20.06 )
AMD Ryzen 7950X 16-core | 64GB DDR5 RAM 6400 Mbps | MSI GeForce RTX 3090 Suprim X 24GB (rendering) | GeForce GTX 1080 Ti FE 11GB (display) | GPU Driver 546.01 | NVMe SSD Samsung 980 Pro 1TB | Win 10 Pro x64 22H2
I’ll have to look into how I have my drives setup. I have an SSD and a SATA, but it has been a few years. I think I have my programs and O/S on the SATA and my files and assets on the SSD.Bobby Parker
phone: 2188206812
- Windows 11 Pro
Yes, turning off displacement solved it, but obviously, that isn't a solution. I was putting on ridge caps and all was going good, up until I put the last one on. Oh yeah, my O/S and applications are on the SSD and my assets are on my SATA HD.Bobby Parker
phone: 2188206812
- Windows 11 Pro
did your max take nearly 2 minutes to start??? that's ridiculously slow.Dmitry Vinnik
Silhouette Images Inc.
ShowReel:
If you notice, it's the V-Ray toolbar that sits waiting to load. I don't know if something before it is holding things up, but that's the last thing that happens before I can do anything. A while ago it was V-Ray waiting for the license, but I thought that was fixed.Bobby Parker
phone: 2188206812
- Windows 11 Pro
Check your RAM Bobby. In one scene I have only roof with displacement and it was terrible. After a while I found this one roof take whole RAM.AMD TR 7980X, 256GB DDR5, GeForce RTX 4090 24GB, Win 11 Pro
2D | 3D | web | video
jiri.matys@gmail.com
https://gumroad.com/jirimatys
https://www.artstation.com/jiri_matys
https://www.youtube.com/channel/UCAv...Rq9X_wxwPX-0tg
https://www.instagram.com/jiri.matys_cgi/
https://www.behance.net/Jiri_Matys
https://cz.linkedin.com/in/jiří-matys-195a41a0
well, vray or not I have vray installed just like you. I also have other plugins, corona, redshift, forest pack etc etc. It takes about 30 seconds to load ui until its responsive.Dmitry Vinnik
ShowReel:
I don't know... I have Forest Pack Pro, RailClone, Walls&Tiles, PSD Manager and I think that's about it.Bobby Parker
phone: 2188206812
- Windows 11 Pro
I would suggest win reinstall, and while you are at it replace hdd with this:
https://www.newegg.ca/Product/Produc...B&gclsrc=aw.dsDmitry Vinnik
ShowReel:
Originally posted by Jiri.Matys View PostCheck your RAM Bobby. In one scene I have only roof with displacement and it was terrible. After a while I found this one roof take whole RAM.Bobby Parker
phone: 2188206812
- Windows 11 Pro
the lag on loading looks like hdd issue to me, is your hdd ssd?Dmitry Vinnik
ShowReel:
- Likes 1
You should probably benchmark your SSD to make sure it is not the issue
And you should have at least 30 GB or so free on your windows drive.. or else this will slow down many thingsLast edited by Muhammed_Hamed; 29-11-2018, 10:11 AM.
I do monitor my drives. My HD is at 100%, but my SSD is getting old. I found errors on the SSD that Windows can't fix, so I am keeping an eye on it. I'm due for an upgrade, so I am looking at my options. The SSD once said 36 days life remaining, but that has been for months and it has gone up since then, so I am not sure how accurate it is.
2 PhotosBobby Parker
phone: 2188206812
- Windows 11 Pro
yup, do look into m2 pci drive, but be sure your mobo accepts it.Dmitry Vinnik
ShowReel:
