Interiors lit with single HDRI still produce square artifacts in latest update. Attached image rendered with GPU default setting sampled to 0.01 , attaching also Lighting and GI render elements. Sending scene archive to support...
update 2 adaptive dome light square artifacts still not fixed
Noemotion.net - www.noemotion.net
Peter Sanitra - www.psanitra.com
Noemotionhdrs.net - www.noemotionhdrs.netTags: None
- Likes 1
Thanks a lot for the scene! Some fixes didn't make it into the release and had to be delayed for the hotfix, but it's good to have the scene to test. I will let you know when I confirm if everything is ok.
VladoI only act like I know everything, Rogers.
Originally posted by tashko.zashev View PostHi Peter,
I can't find any ticket received yesterday related to this issue in our system, do you have a ticket number ? Did you use any file sharing service ?Noemotion.net - www.noemotion.net
So this will be fixed properly for the hotfix, but in the meantime, the artifacts in the RGB channel will go away if you disable the "Max ray intensity" option in the Settings tab of the render setup dialog.
- Likes 2
Great,thank you!Noemotion.net - www.noemotion.net
hihi, this thread gave me a heart attack. ^^Lele
emanuele.lecchi@chaos.com
Disclaimer:
Originally posted by ^Lele^ View Posthihi, this thread gave me a heart attack. ^^Noemotion.net - www.noemotion.net
- Likes 1
Originally posted by vlado View PostTechnically the "max ray intensity" option is a hack too... but I need to make it work
VladoBTW, Did Max Ray Intensity slow down renders? If my memory serves me right, the higher MRI is, the slower rendering is and setting it to a very low value gives a good render speed boost, but unfortunately, at the expense of darker rendering results. Correct me if I'm wrong, but disabling MRI is the physically correct way to render as it doesn't limit the ray intensities? Of course, as I mentioned, drawback is fireflies and slower rendering.
Aleksandar Mitov
www.renarvisuals.com
office@renarvisuals.com
AMD Ryzen 9 9950X 16-core
96GB DDR5
Anyways, i tried to render with disabled "Max ray intensity" option, but i can still see the blocks in beauty/rgb, above sofa. It is more visible when viewing in linear instead of sRGB/OCIO. this region is 0.005 and 10000 samples.Last edited by psanitra; 06-06-2019, 11:32 AM.Noemotion.net - www.noemotion.net
Originally posted by Alex_M View PostWhat if the denoiser had a firefly removal option? AFAIK, Vray denoiser currently just blurs fireflies together with the nearby pixels instead of effectively detecting and removing them like Nvidia's denoising algorithm.
It's limited in that it won't deal directly with lumps of fireflies, but it will work with successive applications.
In this case the fireflies produced by disabled or very high Max Ray Intensity would be gone and Adaptive dome would work as expected? Just a guess, of course.
If you let a render run with unlimited max subdivs, those fireflies would theoretically converge into proper lighting, sooner or later.
At any noise threshold, however, they currently still require loads of samples and often end up "capping" max AA subdivs.
Whichever way you look at them, they are a veritable nuisance.
Hopefully things will improve for these soon enough.
i can show you a glaring (ah-ah.) example.
Lele
Disclaimer:
Originally posted by vlado View PostSo this will be fixed properly for the hotfix, but in the meantime, the artifacts in the RGB channel will go away if you disable the "Max ray intensity" option in the Settings tab of the render setup dialog.
Aleksandar Mitov
96GB DDR5
