Alsurface black buckets in render - urgent
  • Alsurface black buckets in render - urgent
    Default alsurface shader with sss mix at 1, with 2 basic meshes intersecting - it gives this render error. SSS values varying per bucket near the intersections.
    Tried several vray versions, same issue all the time.
    Tried rendering in progressive (still slight flicker) and cryptomatte didn't come out correctly on the meshes with alsurface.
    What's the issue here? Have a tight deadline and i would like to know what's causing this and if it's fixable or not......
    This doesn't happen if the meshes aren't intersecting, but i have a shot to do that require alsurface and several meshes are intersecting.
    Can't seem to reproduce this, could you send the scene to support@chaosgroup.com so we can take a look?
      Sent it right now, buckets where the geometry intersect.
      159-140-4757 
        Hello,
        Indeed there's an issue around the areas of intersection, so I've logged it in our bug tracker under VMAX-9164. A possible workaround would be to increase a bit the sss density scale value or decrease the sss radiuses.
        Philip
        Philip Shounev
        QA department
        Chaos
        philip.shounev@chaos.com
          I understand, but it's still there in the animation, doesn't matter the radius or density. I recreated the sss effect via sss2 and some blend materials for now. Any ETA or when this gonna be fixed?
            Our developers are already investigating the problem. I'll additionally bump its priority.
            Philip Shounev
            QA department
            Chaos
              Thank you.
                Any updates or ETA on this?
                  A potential solution for the above mentioned issue has been developed. You can try it out by downloading the latest stable from our nightly builds page.
                  Philip Shounev
                  QA department
                  Chaos
                    It's fixed, thank you very much guys!
