Material Editor background not working with Vray 5 v2.3 and 3dsMax 2023 ( and blue tint on sphere & background)
  • Material Editor background not working with Vray 5 v2.3 and 3dsMax 2023 ( and blue tint on sphere & background)
    Software: Installed 3dsMax 2023 about 2 weeks ago (issue persisted then too, but this is getting frustrating). Using latest Vray version 5 Update 2.3
    Issue: (see attached images):
    Scenario 1: "Native 3ds Max material swatches" UN-checked in Vray settings. When "Background" checkerboard enabled in Material editor NO checkerboard is shown and material and background get a deep blue/purple tint.
    Scenario 2: "Native 3ds Max material swatches" CHECKED in Vray settings. When "Background" checkerboard enabled in Material editor checkerboard IS shown BUT material sphere goes deep solid BLUE and material CANNOT be previewed,
    I tried swapping out with a B/W checker board for custom background, but that is just shown blown-out/pure white. (blue tint goes away)
    Sort of similar problem to this post, but not quite...something else is going on.
    https://forums.chaos.com/forum/v-ray...ems-with-vray5
    How can I solve this? Did some new check box combination happen with this Max 2023 and Vray that needs to be checked for proper preview. I can't preview refractions with this issue,..
    Thanks,
    Norbert
    Hey norbertm,
    We're aware of this issue and it is logged under VMAX-12159 for developer investigation (discussed also in this post). We'll let you know once we have an update on the matter. Thanks for the understanding!
    Nikoleta Garkova | chaos.com
      Thank you! Thought I was going crazy...
        I am having the same issue here. MAX 2023 and the latest V-Ray
        Bobby Parker
        www.bobby-parker.com
        e-mail: info@bobby-parker.com
        phone: 2188206812
        My current hardware setup:
        • Ryzen 9 5900x CPU
        • 128gb Vengeance RGB Pro RAM
        • NVIDIA GeForce RTX 4090 X2
        • ​Windows 11 Pro
          Yep same here, blue background under the checker box. On a side issue I did briefly try Vray 6.0 beta out of curiosity and LOL the IPR just went black
          Cheers,
          Jason
          AMD Threadripper 3990x 64C Processor, 128 GB DDR4-3200 Ram, 48 GB PNY Quadro RTX A6000, ​Windows Pro 10.0.19045.4894, 3dsmax 2025.3, Vray 62006, Vantage 2.5.2​
            Any solution? Is it still unresolved after a year?
              Having the same problem. Anyone from Chaos looking into this?
                The issue should be fixed and implemented in the latest official builds. Which V-Ray build version do you have installed?
                  Sorry for the delay. I'm pleased to say that it works correctly now.
                    Solved?
                    I still have the problem. Even with the latest Nightlies version (vray_adv_61020_max2023_x64_32282)​
                    Windows 10 - RTX 3090 - AMD Ryzen 9 5950X - 128 Go RAM
                    Sketchup PRO 24.0.594 + V-Ray 7.00.01
                    3DS Max 2024.2.7 + V-Ray 6.20.06
                    3DS Max 2025.3 + V-Ray 7.00.04
                    Chaos Vantage 2.7
                    GeForce Studio Ready Driver Version 566.14​
                      I am experiencing the same problem on 3ds max 2024.1 (update to 2024.2 didn't help) and v-ray nightlies vray_adv_61020_max2024_x64_32279 (update to vray_adv_61020_max2024_x64_32344 didn't help). It did work until end of last week without any problems though...
                        Nevermind, my bad. I must have accidentally enabled the "3ds max material swatches" in the render setup > settings > system
                        DCHA34 DId you check if that's enabled for you as well?
                          FritzBaass Can you take a screenshot of your correct material display?
                          Chaos Vantage 2.7
                            Sure:
                            ​​ Click image for larger version  Name:	grafik.png Views:	0 Size:	313.0 KB ID:	1195528
                            Click image for larger version  Name:	grafik.png Views:	0 Size:	80.1 KB ID:	1195531
                              Here are my screenshots. Is this correct? I'm not sure.
                              Chaos Vantage 2.7
