Vray6 - Forestpack V7.4.3 - Different Results
  • #16
    RedStar
    Dit you check whether the v5-file had black fog values while rendering OK? If not: how did v6-files suddenly have black fog values?
    • #17
      Originally posted by trick View Post
      RedStar
      This is what I am not 100% certain about. If the black value changed on its own or if Vray5 had it as well but it was working properly. What I do know is the scene did not change 1 bit on my end from good to bad render. I updated Vray and had to start rendering final assets for a client project, then noticed my envionrment looking different than before so had to start narrowing down the source.
      At this point I do not want to really downgrade once more to Vray5 to figre out more about this, at least now I see what caused Alpha to not work so I can fix it quickly. Luckily all my other big fpack scene files are rendering as they were which is wonderful.
      • #18
        If you could pass us a scene, we'd be grateful.
        Lele
        emanuele.lecchi@chaos.com
        Disclaimer:
        • #19
          Hi I tested the following - created a scene in 3ds max 2022/v-ray 5 with black fog colour and rendered, here is the result:
          Click image for larger version  Name:	3dsmax_2022-07-26_18-08-54.jpg Views:	0 Size:	423.9 KB ID:	1155246
          I then opened the same scene in 3ds max 2023/v-ray 6 and rendered and here is the result:
          Click image for larger version  Name:	3dsmax_2022-07-26_18-08-42.jpg Views:	0 Size:	422.4 KB ID:	1155247
          I don't know why it renders differently as you can see in V-Ray 6 all the opacity affected areas render as black.
          I am not using forest pack - just a plane with VRayMtl assigned to it and a dome light.
          This might be a bug, let me do a bit more research and I will get back to the thread to eventually share the info or report it as a bug.
          Vladimir Krastev | chaos.com
          • #20
            The blackness disappears when thin-walled is checked.
            I'd chalk this to a bug, as opacity should not have anything to do with the fog color.
            Run the script below to fix the offending materials while the devs work on a proper fix.
            Code:
                for m in ( getClassInstances vrayMtl) where (m.texmap_opacity != undefined and m.texmap_opacity_on) do m.refraction_fogColor = white
            Lele
            Disclaimer:
            • #21
              I just had a quick look in a bunch of commercially available assets and it seems some have a black fog value. Since I never had any problems rendering transparent areas as black, I also think this must be a v6-related bug (or change!). Just to be clear again: I don’t have v6 (yet!).
              • #22
                Good to know, hopefully this will be fixed asap.
                A.
                www.digitaltwins.be
                • #23
                  You Rock! Thank you for taking the time to do this test to show our point.
                  • #24
                    It will be very helpful, if you remember where are those assets from.
                    Peter Matanov
                    Chaos
                    • #25
                      Sure. But I have to look in the original libraries. Most of my assets are resaved (because a lot of the originals have notetracks and/or anim layers - especially Maxtree - which can dramatically ruin saving and loading speed and scene handling, and when Forest Pro loads these as references loading time will be VERY dramatic), so I have to be sure fog is black in the original files.
                      I know that a lot of the Globe Plants (just opened some of lib 19 Temp. plants) have a grey (128,128,128 ) fog color, while using opacity maps.
                      If I find more, I will report here.
                      • #26
                        I have reported the issue under VMAX-12441 in our system for developers review.
