VRayBitmap not update
  • #16
    I am on location now; so cannot check, but I know the last time I was using IPR. Swapping textures while using IPR is common. Would be ideal if those worked in tandem.
    Perhaps this is the difference.
    • #17
      No really...I have the same taught, so I disable IPR and try again, the issue still remain
      Jackie Teh
      3ds Max 2023, V-Ray 7 Hotfix 2 [7.00.08 build 00000]
      AMD Ryzen 9 7950X 16-Core Processor@4.50 GHz | 64GB RAM | Nvidia RTX 4090
      Website: https://www.sporadicstudio.com
      Email: info@sporadicstudio.com
      YouTube: https://www.youtube.com/c/SporadicStudio
      • #18
        Could you share a video where you reproduce the issue?
        • #19
          I do not have a video now, but this is a screenshot of when the issue happened, hope this clarify you.
          Jackie Teh
          • #20
            I managed to reproduce the issue - it seems to happen when there are more than one VRayBitmaps that load the same texture. Even if you delete the duplicate node, the issue persists. However, a fresh VRayBitmap with another texture will update fine. Can you confirm this?
            • #21
              I will have to test, but last time I encountered the error I was indeed loadng the same texture twice.
              • #22
                Confirmed: instanced vraybitmaps do not -ever- refresh the contents of the pathed file.
                Edit:
                Workaround: Show the map in viewports, that will force a cache update, and in the process unlock the cache for the rest of the instance bitmaps, for which then a "reload" or "view image" will work as intended.
                P.s.: the offline render is unaffected, regardless, and always renders with the latest version of the maps.
                Lele
                emanuele.lecchi@chaos.com
                Disclaimer:
                • #23
                  Any solution for this?
                  I am using Joelaff method currently
                  Jackie Teh
                  • #24
                    You can do one of two things: show the map/material in viewport, or start an offline (i.e., non-IPR) render.
                    Either action will invalidate the cache and allow for the refreshing.
                    Lele
                    Disclaimer:
                    • #25
                      Is offline render same as bucket render?
                      Jackie Teh
                      • #26
                        Yes, anything that isn't IPR.
                        Lele
                        Disclaimer:
                        • #27
                          I've logged the issue (internal bug-tracker id: VMAX-12949) for developer investigation.
                          • #28
                            Thank you for clarifying. same issue even not using IPR
                            Jackie Teh
                            • #29
                              Thank you for your help.
                              Jackie Teh
