Merging objects from a scene made in different units changes the Radius in VRayEdgesTex
  • Merging objects from a scene made in different units changes the Radius in VRayEdgesTex
    If I merge an object from a scene made in different units, the Radius in VRayEdgesTex changes and I have to readjust it. This happens with every scene that has different units, for example when working in a scene with inch units and merging an object made in cm units. It's a pain to readjust the radius every time. Please see the screenshots below.
ID:	1171612 Click image for larger version
    Aleksandar Mitov
    www.renarvisuals.com
    office@renarvisuals.com
    AMD Ryzen 9 9950X 16-core
    96GB DDR5
    I keep noticing this as well: https://forums.chaos.com/forum/v-ray...nt-scene-units but also with other maps.
    Vladimir tested it and he says he doesn't have it. I didn't have the time to keep testing it, but I still encounter it.
    A.
    www.digitaltwins.be
      Hi maybe I am doing something different? Please check the tread that Vizioen mentioned and let us know how it goes. Meanwhile I will test again in a simple scene.
      Vladimir Krastev | chaos.com
        Alex how are you merging objects or materials in the scene? Meaning through File > Merge or maybe through Connecter for instance?
        A.
        www.digitaltwins.be
          Thanks, I'll check.
          I'm doing a regular File > Merge operation.
          Aleksandar Mitov
          96GB DDR5
            Any ideas or solutions? The link in the 2nd post doesn't seem to provide any.
            Aleksandar Mitov
            96GB DDR5
              Are you sure your geometry has not been scaled or anything? I tried with newly created clean objects and scene and could not find a fault.
                I updated my thread about this problem with a video: https://forums.chaos.com/forum/v-ray...33#post1173233
                A.
                www.digitaltwins.be
