I have reported this in the past, but I can't seem to find it. My viewport freezes often. I can save and pulldown menus, but the viewport is dead. I can hide everything; everything is hidden, but the viewport doesn't update. This happens when I stop a render and happens often. Everything on my machine is updated, including video driver (RTX 4090).
Viewport Fails
Viewport Fails
Bobby Parker
www.bobby-parker.com
e-mail: info@bobby-parker.com
phone: 2188206812
- 128gb Vengeance RGB Pro RAM
- NVIDIA GeForce RTX 4090
- Windows 11 Pro
Tags: None
It's simply that you have Disabled the viewport is it?
https://help.autodesk.com/view/3DSMA...5-D111CB680366
If that is your problem the viewport will have the word "<Disabled>" at the top. If it's not the issue, I have no clue, sorry. (If you accidentally hit Control-Shift-D, which is surprisingly easy to do, as I end up doing it at least a couple times a week.)
No, that isn't it, but thank you. I cancel a render and 50-50 chance the viewport freezes. I am sure it'll fix itself someday, but it has been this way for a few months.Bobby Parker
phone: 2188206812
- Windows 11 Pro
Weird. What exactly do you mean by the viewport freezes?
Viewport issues sounds like GPU drivers. Make sure you have exactly (not newer or older) "Recommended NVIDIA driver for V-Ray GPU is version 546.01" as it is the recco for VRay, and works well with Max.
I am working in CPU, but I also rolled back to the recommended GPU, which didn't help. Freeze, I mean, it doesn't update. MAX isn't freezing; only the viewport is. I can't pick anything, but I can turn off/on layers, but again, it doesn't update in the viewport.Bobby Parker
phone: 2188206812
- Windows 11 Pro
Remember the drivers are what actually draws to the screen. That would definitely be my first suspect. Can you look at your update logs and maybe see if they were updated when the issue started? Windows will auto update nvidia drivers unless you just through some registry hoops. Check your current version in the nvidia control panel to be sure they are indeed that specified version— nothing older or newer.
Also make sure you are using the studio driver, not the gaming driver.
Correct driver (per GPU page) and is still froze the viewport after a render cancel.Bobby Parker
phone: 2188206812
- Windows 11 Pro
Okay, I think I know what is going on. I have a script that sends me a text through Telegraph when MAX finishes a render. When I cancel a render when the script is enabled, it freezes the viewport. If I let the render finish, it works as it should.Bobby Parker
phone: 2188206812
- Windows 11 Pro
- Likes 1
Nope! Still freezes without the plugin enabled.Bobby Parker
phone: 2188206812
- Windows 11 Pro
Nope! It still freezes without the plugin enabled.Bobby Parker
phone: 2188206812
- Windows 11 Pro
I just updated both Railclone and Forest Pro (both got updates this week), and it is happening almost every V-Ray cancel now. Railclone was the other day, and nothing changed; it was today when I upgraded Forest Pack that has gotten worse.Bobby Parker
phone: 2188206812
- Windows 11 Pro
Bobby Parker
phone: 2188206812
- Windows 11 Pro
Any chance that executing the Maxscript line enableSceneRedraw() fixes your viewport in these situations? What you describe sounds like what I typically experience when one of my scripts crashes halfway, where the viewport redraw has been disabled at the beginning to speed things up, and then the command to re-enable it doesn't get executed.
https://forums.chaos.com/forum/v-ray...ng#post1166964
https://shorturl.at/iqG68Last edited by Alex_M; 19-02-2024, 12:38 PM.Max 2023.2.2 + Vray 6 Update 2.1 ( 6.20.06 )
AMD Ryzen 7950X 16-core | 64GB DDR5 RAM 6400 Mbps | MSI GeForce RTX 3090 Suprim X 24GB (rendering) | GeForce GTX 1080 Ti FE 11GB (display) | GPU Driver 546.01 | NVMe SSD Samsung 980 Pro 1TB | Win 10 Pro x64 22H2
Yes, I usually use DR. I'll pay attention if it happens when I don't. I tried the command line thing posted above, but it didn't do anything.Bobby Parker
phone: 2188206812
- Windows 11 Pro
