I've had this issue on a couple projects with very long render times with many clippers, it seems that the more clippers you add to a scene the longer it takes to render. Anyone else having this issue or know of a workaround? Vray 6.10.08, 3dsmax 2023
Vray clipper...long render times
Same in the previous Vray version. I needed to animate opening a Machine. Doing so with booleans ended up in a terrible mess of dancing triangles during animation (which has not been seen in the Viewport preview. The Animated boolean worked pretty good. Only in the final rendering it go mad and I haven't found the right way to get this fixed))
Then I felt lucky about remembering the Clippers... but I needed to dismiss it, since it became useless on render time. (est. 5-7 times longer approx) A bit pitty all in all:Last edited by caypiranha; 01-02-2024, 02:53 PM.
