Glass Displacement Copies
  • Glass Displacement Copies
    I'm getting a strange moire pattern when copying the glass pane on the left-side. There is vray displacement on the glassThere are no intersecting faces. Max levels set to 20.
    LunarStudio Architectural Renderings
    HDRSource HDR & sIBL Libraries
    Lunarlog - LunarStudio and HDRSource Blog
    can this be reproduced in another scene or its just this one?
      Looks like the mapping is different, check/Redo the UVW's?
      Eric Boer
      Dev
        Exact same copy - checked the UVWs too. Here's a different scene with same mat. I didn't let it finish:
        Here's the file in case anyone wanted to toy around with it:
        click me
          The File seams to be bugged... at least with me...
          Can You send it via mail << nikki@chaosgrop.com >>
          nikki Candelero
          .:: FREE Your MINDs, LIVE Your IDEAS ::.
            reset xform
            reset xfrom from the the utilities panel, then collapse and re-apply your uvw's amd displacemap.
            Might help.
            Peter
              what version of max? i cant open with max7
                Elf, file opens fine in max7 sp1 here.
                Looking into problem now.
                  Ok, it appears that the problematic piece of glass had the UVW applied while in subobject mode.
                  Whereas the other panes have the UVW map applied normally
                  Remove the UVW map, turn off subobject mode and reapply it. Problem appears to be fixed. (couldnt be assed waiting for whole render but the LC looks correct now)
                    Originally there were two seperate mats in sub-object mode as stated. One was a plain glass for the back/sides, and the front had the vray displacement map on it.
                    I thought it would be possible to shift+click copies and that it would reproduce itself with similar subobject UVWs. It looks as if this loses these properties.
                      weird, cause shift dragging should make an identical copy of what you just cloned.
                      Ah well it least you can make it work now.
