I'm getting a strange moire pattern when copying the glass pane on the left-side. There is vray displacement on the glassThere are no intersecting faces. Max levels set to 20.
can this be reproduced in another scene or its just this one?
Ok, it appears that the problematic piece of glass had the UVW applied while in subobject mode.
Whereas the other panes have the UVW map applied normally
Remove the UVW map, turn off subobject mode and reapply it. Problem appears to be fixed. (couldnt be assed waiting for whole render but the LC looks correct now)
Originally there were two seperate mats in sub-object mode as stated. One was a plain glass for the back/sides, and the front had the vray displacement map on it.
I thought it would be possible to shift+click copies and that it would reproduce itself with similar subobject UVWs. It looks as if this loses these properties.
