VRay and shave & Haircut
  • VRay and shave & Haircut
    hi again,
    we're making a little spot at the moment with some letters wich have to be coverd with grass.
    i've used shave & Haircut in max 8, renderd as geometry.
    here an example
    its only a 2 second animation, the rendertime is about 5 min. per frame,
    but on every frame he needs about 30 min. for prepairing the hole thing, and uses more than 2 GB memory. i think there isn't to much geometry in there round about 20.000 hairs with 3 knot points.
    is there anything for speeding it up?
    like a cache or something?
    best regards
    jonas
    Jonas
    www.jonas-balzer.de
    www.shack.de
    I'm not sure if you can generate the geometry to the viewport and then export that as a proxy, but it might be worth a try.
    Other than that, have you looked into VRayFur?
      hi vlado,
      yes VRay Fur is great, i've first try'd it, but i'am missing that you can use instanced geometry. there are two hair segments, the grass and the flowers.
      and the material editor in shave & haircut is great i think.
      the problem with the proxis is that the grass is animated.
      there are one vray light and one spot in there, and he needs about 15 min. for "preparing the global light manager".
      best regards
      jonas
      Jonas
      www.jonas-balzer.de
      www.shack.de
        try lowering the face/level coef. to 0.6 in the Vray: System rollout.
        That should give you a nice speed boost
          hi daforce,
          i've allready set it to .8, but i'll try with .6
          thanks
          Jonas
          www.jonas-balzer.de
          www.shack.de
            Hi Da force,
            Tom schuelke here, sitting next to jonnybefree...
            your idea seems to boost it ...
            very nice.
            Tom
            what exacly does this spinner do ?
            Jonas
            www.jonas-balzer.de
            www.shack.de
              I dont know exactly how to explain it. Best to look here.
              http://www.spot3d.com/vray/help/VRay...ams_system.htm
              Basically for scenes like that with lots of grass etc.. lowering that will help speed up the render, but it will use more memory, you can probabaly go even lower still.
              Good to know it helped
                thanks a lot for your helps vlado and daforce.
                you've saved us 2 hours of sleep last night.
                but after a long long night, the client tells us that he wants to change everything!!
                so best greetings
                jonas
                Jonas
                www.jonas-balzer.de
                www.shack.de
                  dah...fecking clients.
                  hehehe.. always glad to help
                    by the way,
                    this a little sequenze from the grass sequenze.
                    10 min. per frame without GI.
                    http://www.jonnybefree.de/Gras.mov
                    Jonas
                    www.jonas-balzer.de
                    www.shack.de
                      heheh cool
                      Looks great
                        just saw the spot on tv - fast turnaround time you got there
                          hi mike.edel,
                          ja am mittwoch morgen mußte das band raus,
                          Mi. um 07.30 morgens warn wir fertig.
                          hatten auch nur 4 tage.
                          schöne grüße
                          jonas
                          Jonas
                          www.jonas-balzer.de
                          www.shack.de
