What if vray could be setup to store the proxies once it loads successfully the first time? That would help take some pain off the network from having a dozen machines re-loading so many proxies every frame.
What is vray doing when it loads the proxies? Does it load them locally?
I think you'd be better off mirroring them locally yourself, the beauty (or bane in your case) is that info is read from the vrmesh files only as it is needed reducing memory usage, so the entire proxy is likely never present on the slave at the same time.
When you say copy them locally, do you then have to remap the paths again. I have this same problem but i'm using lots of different proxies in different paths. It's a real pain to go through and change all the paths one by one.
