displacement
  • displacement
    I have a plane that I can't get displacement to work on. I can crank the displacement up to 10' and it is still flat. Any clues?
    Bobby Parker
    www.bobby-parker.com
    e-mail: info@bobby-parker.com
    phone: 2188206812
    My current hardware setup:
    • Ryzen 9 5900x CPU
    • 128gb Vengeance RGB Pro RAM
    • NVIDIA GeForce RTX 4090
    • ​Windows 11 Pro
    funny u mention it, i found the same problem...i had to switch over to 3d displacement to get it done...2d displacement just didn t work on a correct tipology!
    Nuno de Castro
    www.ene-digital.com
    nuno@ene-digital.com
    00351 917593145
      Do you have a scene for this? Did the geomtry have proper mapping coordiantes?
        displacement
        It is mapped the way I have always mapped it. It worked up until yesterday. I exported the object out to Autocad and then imported it back into MAX. Once back into MAX I applied the UVW and Displacement. Would you like to see the model?
        Bobby Parker
        phone: 2188206812
        • Ryzen 9 5900x CPU
        • ​Windows 11 Pro
          Yep, like I said, a scene would be good to take a look at. You can send one to vlado@chaosgroup.com
            done
            Nuno de Castro
            www.ene-digital.com
            00351 917593145
              Thanks for the scene. The problem is that for 2d displacement mapping you need to use Explicit UVW mapping coordinates for your bitmap. Object XYZ is not going to work. This is because 2d displacement pre-samples the displacement map separately from the geometry and it cannot provide the required 3d coordinates, but only 2d UV ones. If you really must use Object XYZ mapping then you have to use 3d displacement.
                shame on me!
                lol
                sory ´bout that and...thanx vlado
                Nuno de Castro
                www.ene-digital.com
                00351 917593145
                  displacement
                  It still isn't working for me. I think something is wrong with my model. The units seem correct, but somthing just isn't working. I'll post when I find out what is up.
                  Bobby Parker
                  phone: 2188206812
                  • Ryzen 9 5900x CPU
                  • ​Windows 11 Pro
                    Can you explain Explicit UVW mapping?
                    Bobby Parker
                    phone: 2188206812
                    • Ryzen 9 5900x CPU
                    • ​Windows 11 Pro
                      i was using a smoke map as a displacemet map, and it was set to object xyz.
                      that was the problem in my scene. just seted the map to explicit map chanel and it worked fine with an uvw maping+vray displacement modifier.
                      Nuno de Castro
                      www.ene-digital.com
                      00351 917593145
                        Re: Explicit UVW mapping
                        In the Bitmap options, on the top , where <Texture>/<Environment> is, there is pulldown menu , to choose the type of mapping.
                        nikki Candelero
                          mapping
                          I was thinking to much on this one... mine is set corect, but it still isn't working. I am thinking I am having an issue with my max9.
                          Bobby Parker
                          phone: 2188206812
                          • Ryzen 9 5900x CPU
                          • ​Windows 11 Pro
                            Re: mapping
                            It was working ok here with your scene, but with a different texture map (I used a newer V-Ray build though, let me know if you want to try it with your scene).
                              displacement
                              Can I try it? I have tried everything, but nothing works.
                              Bobby Parker
                              phone: 2188206812
                              • Ryzen 9 5900x CPU
                              • ​Windows 11 Pro
