slow material editor with vray 64
  • #31
    I also have the slow material editor prob. Hah, I thought it was just me.
    and HP's site has been promising printer drivers "soon" for months now.
    I'm pretty happy with everything else win64, except, I recently discovered that when rendering to AVI uncompressed in Premiere pro 2.0, it works, yet win64 can't play/open the file with win media player, or win media encoder 32 or 64.
    I thought I was producing corrupted files through Premiere, until I finally realized that I could open them on an older XP 32 machine.
    • #32
      geoffc - thank you very much! i had this exact problem today with a fusion comp. I thought i was going to go insane. I should have tried on a 32bit machine.
      Chris Jackson
      Shiftmedia
      www.shiftmedia.sydney
      • #33
        slow Materials Editor
        I have the slow Materials editor too...
        I wonder if the new extension-patch from Autodesk which is just around the corner will fix that. And I also wonder if the 1.5 final is somewhat tied to that release???
        • #34
          Nixon, vlado has said that it has been sorted for RC4
          Chris Jackson
          Shiftmedia
          • #35
            I've got this problem, and so many more problems with Max 9 64.
            Every time i re-open the material editor, i've got to wait about 3-4minutes before i can use max again while each stupid little matieral slot takes ages to load. This is such an issue, i use it almost every 30 seconds or so!
            I have to wait for a few minutes at the beginning of each render while it transforms vertices; again another problem fixed in rc4.
            I've emailed and politely requested a fix, but no responce. I don't understand why other people are supplied with a fix, and some not. We all know that the RC's are release candidates; i know that there is a risk in using RC4, but there is the same risk in using RC3 or RC2 etc. etc.
            At the moment i have some really annoying performance issues that are real hiderances to my workflow, and nobody knows when the next release will be. Is it going to be like 1.47 + when it was practically years before the next official release? I just can't keep using max this way when i recogn i'm waisting about an hour or two hours a day just waiting for Max to come back under my control...
            ***sorry for the rant, just getting frustrated...***
            • #36
              SV i realise your frustrated but maybe give vlado a PM he should be able to help out
              Chris Jackson
              Shiftmedia
              • #37
                file link reload problems with autocad. floating point issue x64 ( object enabler) > Autodesk has been briefed. hoping for fix in SP1
                We are having this problem - does your FLM suddenly stop working from ADT?
                Kind Regards,
                Richard Birket
                http://www.blinkimage.com
                • #38
                  Does it help if you set the ME to only update the active slot?
                  Eric Boer
                  Dev
                  • #39
                    I try to leave the material editor open, and just move it down to the bottom, without minimizing it. Normally it doesn't have to regen as much this way.
                    • #40
                      From what I hear from u guys, 64bit land is really scary
                      Will it be - or is it now - worse with vista 64?
                      My Youtube VFX Channel - http://www.youtube.com/panthon
                      Sonata in motion - My first VFX short film made with VRAY. http://vimeo.com/1645673
                      Sunset Day - My upcoming VFX short: http://www.vimeo.com/2578420
                      • #41
                        64bit land is not scary! Its fantastic.
                        Chris Jackson
                        Shiftmedia
                        • #42
                          I love 64bit land.
                          Now Vista land, whether it be 32 or 64, that sends me shivers!!
                          • #43
                            This might be worth a try:
                            System tab > check dynamic memory limit to 2000MB or similar (800-1200MB at least) depending on your amount of RAM
                            Even your default geometry is treated as static, VRay proxies/ebjects and VRay displacement modifier are threated dynamically.
                            I hope this helps.
                            --> http://www.tobyatwork.de
                            --> http://www.scriptspot.com/blog/toby
                            • #44
                              I also have problems with slow material editor. It's a bit better with RC4 but still. Ive found out that material editor is only slow when working you have even one multi-sub material...then you're doomed .
                              Luke Szeflinski
                              :: www.lukx.com cgi
                              • #45
                                Well, this particular issue seems to affect mental ray as well (multi/sub materials) or so they say on the Autodesk discussion forum, so I don't think there is much to be done on the V-Ray side.
