Vray crashes high res rendering
  • #16
    12 spot lights and GI enviorment Multiplier 10
    • #17
      settings seem fine.
      Your using vrayshadows I assume.
      Sometimes having such a high environment multiplyer can slow things down, especially combined with unusual color mapping. What are your color mapping settings?
      • #18
        Yes I use vray shadows
        For color mapping/ Gamma correction / Multiplier 0.454 / Inverse gamma 0.454 / Gamma 1.0 / Sub-pixel unchecked / Clamp- checked / Affect background checked
        • #19
          if you want to gamma correct the image you don't need both multiplier and inverse gamma at .454, you're actually making it darker this way. leave multiplier at 1.0 and just apply the inverse .454 gamma. or leave both at 1 and set gamma at 2.2
          you may also want to check sub pixel mapping on, I spot a couple of artifacts that you can solve this way.
          since I can't come up with anything better: how many subdivisions are you using for those reflective/glossy mats such as floor and wood?
          • #20
            mmm sounds like your using LWF.. you need to keep the multiplyer at 1.0 and just change the inverse multiplyer otherwise its not LWF.
            Are you using any proxies. If so how many, how are they setup.. i.e. one tree proxy instances lots of times.. or a huge forrest as one proxy..etc..
            Are you using dynamic or static memory in the Vray: system rollout.
            You might want to try ditching the environment and switch to a dome light instead perhaps.
            Will be able to suggest more when I can see your render.
            • #21
              here it is, hope mjaco doesn't mind me mirroring it:
              • #22
                No i don't mind at all, you saved me some time
                I was extualy in middle of setting up at a free hosting site
                Thanks
                • #23
                  Hmmm well the roof looks a little funny.. quite a few splotches.. I guess thats due to the low IR map settings. That one rendered in 1h16mins.. does the higher reolution still take HEAPS longer even with those settings.. like did you change/lower them for that smaller render?
                  • #24
                    Yes the higher reselution is the same settings as the lower one,
                    • #25
                      Ok, what about your material subdivs.. for glossy
                      • #26
                        Wood, floor, are 16
                        Gold is 30
                        • #27
                          What would you guys predict a normal render time for a scene like this at 3400x2200?
                          • #28
                            30 seems a little high especially for that distance. Wouldnt think it would kill the render too much.. but then again.
                            So after re-building the IR and LC maps.. was it any quick for high res?
                            • #29
                              if i change the gold to 16 from 30, would it require me to re-build the LC and the IR?
                              • #30
                                I also have that envierment picture set up in the reguler enviermnet slot in max and in vray i have the blue sky color with a multiplier of 10 (I'm gono try to lower that as you mentiont maby if i'll change my color mapping multiplier to 1 i'll be able to lower it) can that have to do with anything?
