Evironment
  • #16
    Dark Shadows
    One thing I am noticing is my shadows are really dark. It is only in the Building Light Cache phase, but I can already tell. Anything I should do or should I just take care of that in post?
    Bobby Parker
    www.bobby-parker.com
    e-mail: info@bobby-parker.com
    phone: 2188206812
    My current hardware setup:
    • Ryzen 9 5900x CPU
    • 128gb Vengeance RGB Pro RAM
    • NVIDIA GeForce RTX 4090 X2
    • ​Windows 11 Pro
    • #17
      I don't know why you think your shadows are too dark maybe you can post another image.
      As far as vary sun/sky and vray cam goes I usually use something around following settings.
      ISO: 100
      shutter speed: 200
      f-number: 8
      I don't burn the gamma into the image usually so i leave the color mapping gamma at 1 and press the rgb button of the VFB.
      Now you are saying that your monitor gamma is 1 but your are setting your gamma at 2.2??? I don't understand. If you monitor is aclibarted at gamma 1 then your gamma should be set to 1 as well. But maybe i am wrong there and a "LWF specialist can confirm or correct.
      I am fairly new in posting here so i don't know how to paste in a picture like you did otherwise i would have shown you an example.
      regards
      ingo
      • #18
        sRGB
        My understanding is gamma 2.2 in v-ray is for v-ray's buffer and is the same as the sRGB button that you find on the VFB.
        Bobby Parker
        phone: 2188206812
        • Ryzen 9 5900x CPU
        • ​Windows 11 Pro
        • #19
          Heheh yes i know that but your monitor has to be calibrated to that gamma then that was my point.
          Ingo
          • #20
            Look at this thread
            http://www.chaosgroup.com/forum/phpB...ic.php?t=15303
            If your momitor is calibrated at gamma 1 then i think you should look at the 3rd method
            Regardz
            Ingo
            • #21
              Gamma1
              How would I know if my LCD was calibrated to gamma 1? I assumed all were. I use Spider Pro, but at no point does it tell me.
              Bobby Parker
              phone: 2188206812
              • Ryzen 9 5900x CPU
              • ​Windows 11 Pro
              • #22
                HU?
                I use the greatg eye one display so i don't know the spyder but don't you have to tell it to what gamma you want your monitor calibrated at????
                • #23
                  Calibration
                  Good question. I'll have to recalibrate.
                  Here are some tests.
                  Bobby Parker
                  phone: 2188206812
                  • Ryzen 9 5900x CPU
                  • ​Windows 11 Pro
                  • #24
                    gamma 2.2 looks correct to me
                    • #25
                      So if you recalibrate your monitor then i would suggest to make it act like a crt monitor meanind calibrate it to 2.2 gamma. This might not be easy but i think that is the prefered option.
                      • #26
                        Gamma
                        Yep 2.2 looks good here to, but it is the same as gamma 1 sRGB save as an EXR.
                        Bobby Parker
                        phone: 2188206812
                        • Ryzen 9 5900x CPU
                        • ​Windows 11 Pro
                        • #27
                          Yes of course.
                          If you save it to float you don't have to do anything but if you save it to 8 bit then ou have to outputit to gamma 2.2
                          • #28
                            Exposure
                            Ok. I have the front of my building looking good, but a little flat. I'll do some PS to get some pop. My question is I am rendering the back and the back is all in shade. Should I leave my v-ray camera settings the same and do a shadow/highlight in PS or should I re-expose my camera?
                            Bobby Parker
                            phone: 2188206812
                            • Ryzen 9 5900x CPU
                            • ​Windows 11 Pro
                            • #29
                              if it is the same camera i would create another one and rexpose
                              • #30
                                Exposure
                                it is a different camera. How would you handle an animation?
                                Bobby Parker
                                phone: 2188206812
                                • Ryzen 9 5900x CPU
                                • ​Windows 11 Pro
