DR and Xref
  • #16
    Well, I'm now trying to put the main file in the same folder as the xrefs to see if that helps.
    Kind Regards,
    Richard Birket
    http://www.blinkimage.com
    • #17
      Hm, that's what I said does not work Best to use Asset Tracker to make sure the XRefs all have proper UNC paths.
      • #18
        asset tracker suprinsingly does not list xrefed objects paths!
        but i confirm so far that xrefed objects work with propper paths (UNC that is)....if i only saw taht back then!
        am testing xrefed scenes atm...will post soon!
        Nuno de Castro
        www.ene-digital.com
        nuno@ene-digital.com
        00351 917593145
        • #19
          Tried UNC paths but still doesn't work. Vlado - I've emailed you.
          Kind Regards,
          Richard Birket
          • #20
            this is like torture. bye-bye weekend.
            Kind Regards,
            Richard Birket
            • #21
              i got it working here!
              Unc paths...xref scene...perfect
              though i cant think of a reason for not being using unc paths back then....
              Nuno de Castro
              www.ene-digital.com
              00351 917593145
              • #22
                (ops....double post)
                Nuno de Castro
                www.ene-digital.com
                00351 917593145
                • #23
                  I seem to have found a possible solution to the problems I have been having - my max camera was 'broken'. I recreated it and suddenly rendering seems to be working again as normal. Now that's a new one!
                  Kind Regards,
                  Richard Birket
                  • #24
                    I remember this could happen if the camera came from one of the XRef files, instead of being in the main file itself.
                    • #25
                      well....
                      in the test i just came up with earlier i rendered from a xrefed cam...and worked fine nonetheless...
                      Nuno de Castro
                      www.ene-digital.com
                      00351 917593145
                      • #26
                        Yeah, it may work; I just remember there were issues with it at some point
