DR and Xref
  • DR and Xref
    i ve been trying to get DR to work properly for the last couple of weeks, with no luck so far...
    Today, because i have some spare time atm, i m trying to figure out whats going wrong.
    I work with Xref scenes on every single projects for quite some time, and its been a great improvment for my workflow so far.
    DR works flawsly for simple geometry tests, but as i try it on the last project for testing the slaves don t kick in...they keep restarting themselves during rendertime. So i ve just tried to merge the Xref scenes into the master file, and DR worked in every single slave!
    i m gonna try afterwards to render with Xref objets to see if it works by any chance...
    note that the Xref are properlly maped with UNC paths as are all the maps...
    Nuno de Castro
    www.ene-digital.com
    nuno@ene-digital.com
    00351 917593145
    Which V-Ray version is that?
      is this working for you, vlado?
      Nuno de Castro
      www.ene-digital.com
      00351 917593145
        ok...
        further testings here...
        if i merge those objects from other file as Xref objects, and not as Xref scene, it works!
        unfortunately it doesn t no matter what if i use the Xref scene...why?
        shouldn t it work as well?
        Nuno de Castro
        www.ene-digital.com
        00351 917593145
          It worked when I tried it recently, but there may be something specific in your files, so it may be useful if you can get me an example to vlado@chaosgroup.com
            will do!
            Nuno de Castro
            www.ene-digital.com
            00351 917593145
              well i can t get it to fail now!
              sory about that vlado!
              Nuno de Castro
              www.ene-digital.com
              00351 917593145
                We also use Xrefs for every project. Some of our projects have DR rendered fine, others fail in just the way you describe. On the ones that fail, I can merge in all the xrefs and they start working. I have not been able to narrow it down to a specific cause yet, but I can confirm that sometimes Xrefs cause DR to fail. (1.50.00 also)
                -Ray
                Ray Collett - Design Visualization Specialist
                WSP USA - Visualization and Data Intelligence
                Visualization & Data Intelligence Portfolio (vizportfolio.com)​
                  i thought i was losing it!
                  thanx for the confirmation of my sanity....or what lasts of it!
                  Nuno de Castro
                  www.ene-digital.com
                  00351 917593145
                    Ok then, will try to reproduce this here.
                      we have also had some trouble with DR and xrefs this morning, all fine when merged tho.
                        I ve had to merge the xrefed scenes every time i have to DR...
                        Nuno de Castro
                        www.ene-digital.com
                        00351 917593145
                          Interestingly, I have not had this problem till I read this thread!! I am now having problems DR with BB with Xref's. Merging does fix it.
                          It seems to work locally with xref and DR still
                            We are now having this problem and it is causing us major grief - deadline looming!
                            We are using Max2009 64bit and Vray 1.5 SP2. It all seemed to be going ok until about 3 or 4 hours ago. We have about 10-15 large buildings that we are xref'ing in as scenes and using DR. It fails every time now. However, if I merge the scenes in, it works fine.
                            Merging is not a viable option though as there are so many different files that we need as seperate max files.
                            Any tips?
                            Kind Regards,
                            Richard Birket
                            http://www.blinkimage.com
                              A common error is that the XRef files are specified relative to the folder of the main scene, or relative to the user's computer (and sometimes the paths are wrong altogether, but 3ds Max finds the scenes because they are in its search paths); however when the main scene is transferred to the slaves for DR, these relative paths are no longer valid and cannot be found.
                              Not sure if this is your problem though...
