error: [VFBCore::SetRegion] Error writing render region to raw image file.
[ExrFile::WTRegion] Error writing tile to .exr file
This is really bugging me, as it happens all the time and it's inconsistent to be able to reproduce it, but i'd say we have about a 50% failure rate when writing directly to an .exr file or a .vrimg through the VFB but only for larger resolution images with the render to memory buffer disabled.
I've just rendered a high resolution still over night, and the resulting .exr file (12meg)won't open now in any program - I didn't render to memory frame buffer as it's high res and i wanted to concerve memory, so now i can't save out the image which is sitting on my screen as a preview!
(*) this only happens during DR, so i've got to conclude it's one of the DR nodes not doing something, or not passing some sort of information around
(*) rendering through backburner is absolutely fine; we shouldn't have any permissions issues with windows, my profile (which all the machines are on) is a network administrator power user
(*) This happens sporadically - sometimes all the DR works fine and saves a high res image, sometimes i just get this error, and if i haven't used the memory frame buffer i'm screwed.
(*) Only when writing to either .exr or .vrimg through the VFB
Am i missing something? Some times this works, sometimes not.
Really don't know what else to say -
Vray 1.5 SP1
I can provide any logs if necessary - see bottom bit of code and standard settings.
(The reason i still had "get resolution from MAX" still ticked was because this has failed before with that option off - i decided this time i'd keep it on, but still an error)
sample end of the vraylog.txt:
[2008/Jan/9|20:09:19] Sending 840004 bytes of irradiance map to media-dwestwood
[2008/Jan/9|20:09:19] Sending 840004 bytes of irradiance map to media-acosta
[2008/Jan/9|20:09:19] Sending 840004 bytes of irradiance map to media-aaver
[2008/Jan/9|20:09:19] Sending 1012 bytes of irradiance map to clusta-render3
[2008/Jan/9|20:09:19] Sending 1012 bytes of irradiance map to media-selliss
[2008/Jan/9|20:09:19] Sending 1012 bytes of irradiance map to media-acosta
[2008/Jan/9|20:09:19] Sending 840004 bytes of irradiance map to clusta-render4
[2008/Jan/9|20:09:19] Sending 1012 bytes of irradiance map to media-aaver
[2008/Jan/9|20:09:19] Sending 1012 bytes of irradiance map to media-dwestwood
[2008/Jan/9|20:09:20] Sending 840004 bytes of irradiance map to clusta-render4
[2008/Jan/9|20:09:21] Sending 840004 bytes of irradiance map to clusta-render4
[2008/Jan/9|20:09:21] Saving irradiance map to file "\\Svserver\Render Output\Claverdon\Claverdon_High_Res_Bathroom.vrmap "
[2008/Jan/9|20:09:21] Sending 1012 bytes of irradiance map to clusta-render4
[2008/Jan/9|20:09:23] Irradiance map saved successfully
[2008/Jan/9|20:09:23] Image prepass completed.
[2008/Jan/9|20:09:23] Rendering image.
[2008/Jan/9|20:09:23] Setting up 8 thread(s)
[2008/Jan/9|21:07:30] Threads completed
[2008/Jan/9|21:07:30] Calling endFrame().
[2008/Jan/9|21:07:30] Entering endFrame().
[2008/Jan/9|21:07:30] Broadcasting NOTIFY_POST_RENDERFRAME.
[2008/Jan/9|21:07:30] Applying render effects.
[2008/Jan/9|21:07:30] Waiting for DR to finish
[2008/Jan/9|21:07:30] Number of raycasts: 1722758282
[2008/Jan/9|21:07:30] Clearing global light manager.
[2008/Jan/9|21:07:30] Clearing direct light manager.
[2008/Jan/9|21:07:30] Clearing ray server.
[2008/Jan/9|21:07:30] Clearing geometry.
[2008/Jan/9|21:07:30] Calling frameEnd() on render instances.
[2008/Jan/9|21:07:30] Calling frameEnd() on render objects.
[2008/Jan/9|21:07:30] Calling frameEnd() on render materials.
[2008/Jan/9|21:07:30] error: [VFBCore::SetRegion] Error writing render region to raw image file.
[2008/Jan/9|21:07:30] Clearing camera image sampler.
[2008/Jan/9|21:07:31] Clearing camera sampler.
[2008/Jan/9|21:07:31] Clearing DMC sampler.
[2008/Jan/9|21:07:31] Clearing path sampler.
[2008/Jan/9|21:07:31] Clearing color mapper.
[2008/Jan/9|21:07:31] Region rendering: 5243.3 s
[2008/Jan/9|21:07:31] endFrame() done
[2008/Jan/9|21:07:31] Updating irradiance map info.
[2008/Jan/9|21:07:31] RenderAtTime() done.
[2008/Jan/9|21:07:31] Stopping frame timer.
[2008/Jan/9|21:07:31] Total frame time: 5262.9 s
[2008/Jan/9|21:07:31] Render() done.
[2008/Jan/9|21:07:31] Entering Close()
[2008/Jan/9|21:07:31] Calling endSequence().
[2008/Jan/9|21:07:31] Entering endSequence().
[2008/Jan/9|21:07:31] Calling renderEnd().
[2008/Jan/9|21:07:31] Calling renderEnd() on render materials.
[2008/Jan/9|21:07:31] Sending RenderEnd().
[2008/Jan/9|21:07:31] Sending RenderEnd() to atmospheric effects.
[2008/Jan/9|21:07:31] Sending RenderEnd() to render effects.
[2008/Jan/9|21:07:31] Sending RenderEnd() to the tone operator.
[2008/Jan/9|21:07:31] Sending RenderEnd() to environment maps.
[2008/Jan/9|21:07:31] Unloading bitmaps.
[2008/Jan/9|21:07:31] Freeing render instances and lights.
[2008/Jan/9|21:07:31] Broadcasting NOTIFY_POST_RENDER.
[2008/Jan/9|21:07:31] Closing DR
[2008/Jan/9|21:07:32] endSequence() finished.
[2008/Jan/9|21:07:32] Sequence timer stopped.
[2008/Jan/9|21:07:32] Total sequence time: 5264.4 s
[2008/Jan/9|21:07:32] Enabling scene redraw and autobackup.
[2008/Jan/9|21:07:32] Close() done.
[2008/Jan/9|21:07:32] error: 1 error(s), 1 warning(s)
[2008/Jan/9|21:07:32] ================================
[2008/Jan/9|21:32:12] Saving to file.
[2008/Jan/9|21:32:12] Saving distributed renderer.
[2008/Jan/9|21:32:12] Saving filter parameters.
[2008/Jan/9|21:32:12] Saving done.
Vray 1.5 SP1
