For the spawner issue specifically, try to disable the viewcube/steering wheel thing (there were some files to rename, but I forget which ones, you can find them on the forum).
Otherwise, the hanging buckets issue I am working on now; it looks like I have a solution, but I need to test a bit more.
The problem is partially fixed, but that's after reinstalling pretty much everything from scratch. DR still doesn't kick in from time to time for some unknown reasons on one machine (maybe a RAM issue)...
As for the xml files... I really don't know if that really helped.
Are you sure your machine ping between one another? Are you sure you are using the right IP address (are you using a router?)? ...
yes all computers can see each other on network and can pass file from one pc to another.
I looked at vraylog of slave and it say that it cannot obtain license.
I installed vray-renderslave files to these.
and the port they use is default settings.
I reserved that port to the main pc ip from modem settings.
are these not right?
I have exactly the same problem as you, I will try to resolve it by following the thread. Everything worked well with MAX8 but the problem occurred since using max 2009.
i have the same problem here too! i have 10 slaves and 3 of them have this strange problem, the other ones runs fine. animation jobs using backburner are running fine only the DR jobs are not running on theese 3 machines.
in max 9 all was fine. using now max 2009 (64bit all) and using sp3.
on one slave i had luck with uninstaling the 9er versions of vray and one slave has another problem. the vray message window says render host added....scene transfered... and usualy then starts render but on one slave nothing happens.
