I've gotten basically the same result. All I did in NUKE was recenter the input vectors @ .5 to zero(so the motion range is -.5 to .5), and then set the range from -1 to 1. You can stick a multiplier on after that, or use the motion vector mult to up the intensity. Of course, as stated before object occlusion is a problem, as is the background. I cheated in this on and recreated the BG to put in to test edge artifacts.
