vRay 1.5 SP5 crash when rendering max's photometric ies lights
  • vRay 1.5 SP5 crash when rendering max's photometric ies lights
    I have problem with interior scene on vRay 1.5 SP5
    UNHANDLED EXCEPTION: Irradiance map thread
    Last marker is at .\src\globillummap.cpp, line 1616: GlobalIllumMap::buildLightMap() {5}
    -When vRay calculate IRR map.
    I have vRay IES lights and max's photometric IES lights (distribution photometric WEB, vRay shadow area 10cm)
    When I turned off photometric - all is fine, but when on - always crash.
    Any idea?
    www.luminancestudio.pl
    What shadow type do you use for the photometric lights?
      vRay shadow with settings:
      Transparent shadows ON
      bias: 0,2
      Area shadow Sphere
      U 10cm
      V 10cm
      W 10cm
      subdivs: 8
        Ok, if it is a reproducible error can you get me the scene to vlado@chaosgroup.com to check it out?
          I sent the scene with .ies file.
          If you render some region of the scene, you will always get the error.
          Thanks for help!
            I found a source of the problem!
            .ies file is wrong. Wheng I change to other .ies file - all is fine.
            Sorry for wasted time.
              Oh ok Good to know.
