different DR-Buckets
  • #31
    Originally posted by Eitzlmayr Simon View Post
    How can i do that (never done this)? - is there a possibility to run max and vray in 32bit mode on the 64bit machine?
    Yes, of course. Just install the 32-bit versions of 3ds Max and V-Ray.
    • #32
      You can't use 32 bit machines and 64bit machines together, simply put, the processors have different architectures, so the processors come up with different results. Our company had the same problem years ago, you can only use a bunch of 32bits or 64bits, the latter is obviously better to use.
      (YES i know you can install 32bit 0S on a 64Bit machine, I'm talking about a 32 bit machine trying to render an image sent by a 64bit machine (unless you set the backburner to send via 32bit). It won't work correctly. So Use a 64bit machines. Simples.
      • #33
        you do realize a 64 bit computer and os can run 32 bit software?
        WerT
        www.dvstudios.com.au
        • #34
          i also think about that!
          is there a possibility to run max32bit on a pc with win7 64bit respectivly max64bit on a win7 32bit ...
          • #35
            you can , as vlado said, install both max 32bit and/or max 64bit on a win7 64bit system. you can“t install max 64bit on a win32bit system!
