Splines/Poly showing up in my glass
  • Splines/Poly showing up in my glass
    I've created a V-Ray frosted tempered glass material which seems to work well. However, on occasion, my wireframe will show up! How do I get rid of it?
ID:	876693Click image for larger version
    David Anderson
    www.DavidAnderson.tv
    Software:
    Windows 10 Pro
    3ds Max 2024.2.1 Update
    V-Ray GPU 6 Update 2.1
    Hardware:
    Puget Systems
    TRX40 EATX
    AMD Ryzen Threadripper 3970X 32-Core 3.69GHz
    2X NVIDIA GeForce RTX 3090
    128GB RAM
    this just looks like bad normals to me. Did you try setting the normal smoothing angle?
    Dmitry Vinnik
    Silhouette Images Inc.
    ShowReel:
      I'm fairly new at this, so bear with me...
      So to set the normal smoothing angle, I do what? I went to the modifier stack in my Editable Mesh I found "Smoothing Groups". The value was 45.0, but I clicked on "Auto Smooth". It did help quite a bit, but it is still there in a few areas.
      Thanks.
      David Anderson
      Software:
      Windows 10 Pro
      Hardware:
      Puget Systems
      TRX40 EATX
      128GB RAM
        for hard objects like this you need fairly low smooth value so the normals don't get rounded too much. There is a value near the smoothing group (45) is a generally accepted good angle but you need to go lower like 15 or 10. If your glass is straight, i.e. there is no dents or imperfections in it, then low value will do the trick.
        Also you can add a smooth modifier overtop of your geometry or multiple objects and control the smoothing groups that way.
        Dmitry Vinnik
        ShowReel:
          i find thin triangles like that also make problems with reflections and refractions. try to remodel it with better topo
            Do you need to have those holes cut into it? Find some tutorials on cutting shapes out, it looks like you've done a boolean and thats a pretty fast track to messy geometry.
            e: http://www.3dtotal.com/index_tutoria...2#.UEYkw_WH98E
              The holes are for the hinge hardware to go through. It's a .max file that my client created with Inventor and passed it off to me to render. The odd thing is that it's only an issue on the black version of the furniture. With the white version, I can't see it at all. I'll check out the link you sent to me. Maybe I need to re-model as Da_Elf suggested. Otherwise, would a third party program like Polytrans, or the like help with eliminating the triangles?
              David Anderson
              Software:
              Windows 10 Pro
              Hardware:
              Puget Systems
              TRX40 EATX
              128GB RAM
                I know you need the holes irl, but can you tell that there is a hole in the render? Surely the hinge hardware can simply pass through the glass?
                If not, you need to remodel it. The link is how to remodel it.
                  No, I wouldn't know why I'd need holes in it... So with that said, can I get away with re-modelling a sheet of glass as a Standard Primitive "Box", or would I need to do something fancier with a mesh? Because it's a finished glass edge, I see that the edges are a bit rounded. So maybe just a line with bezier corners and then an extrude modifier?
                  Thanks for helping this newbie out!
                  David Anderson
                  Software:
                  Windows 10 Pro
                  Hardware:
                  Puget Systems
                  TRX40 EATX
                  128GB RAM
                    Okay, so I added an "Edit Mesh" to the stack modifier and then deleted the holes. Along with the holes deletion, went those pesky triangles! Now I have a nice piece of glass with the same rounded edges.
                    Thanks everyone!
                    Dave
                    Edit: Not to belabor this thread, but it turns out that I didn't need to add and "Edit Mesh" modifier to the stack. I just opened the "Editable Mesh" stack, selected the vertexes and deleted what I didn't want.
                    David Anderson
                    Software:
                    Windows 10 Pro
                    Hardware:
                    Puget Systems
                    TRX40 EATX
                    128GB RAM
