Backburner wont save completed renders
  • #16
    Are you doing print stuff deflix? You can use the built in vrimg2exr utility to convert, especially if it's only a few renders.
    • #17
      Originally posted by deflix View Post
      Just checked the official documentation
      Save separate render channels - this option allows you to save the channels from the VFB into separate files. Use the Browse... button to specify the file. This option is available only when rendering to a memory frame buffer. If rendering is done only to a raw image file, the render channels can be extracted from that file after rendering is complete.
      You lost me here - does it means it works the way you want to or no?
      • #18
        Think i will stick with direct output unless I hit a memory limit. Having said that I think it was BB that caused the problems this time.
        thnks for input anyway
        Immersive media - design and production
        http://www.felixdodd.com/
        https://www.linkedin.com/in/felixdodd/
        • #19
          Yeah all fine thnks, just that you cant 'directly' get separate passes out without using the memory FB.
          no probs just mildly annoying ...
          • #20
            mite buy pdplayer
            • #21
              Yes you can get them separably.
              IF you have 10 render passes and then u use EXR with no render passes added in settings they all should save in separate files, or go to render passes and pick directory where to save 1 by 1. One u set it up they go automatically from that point.
              • #22
                there is a tool that comes with vray called vrimg2exr converter that converts the vrimgs to exrs and spits out the passes, as far as i know you can use pro exr in ae or photoshop to read them in.
                Dmitry Vinnik
                Silhouette Images Inc.
                ShowReel:
