How does VrayMTL translucency work...?
  • #31
    Tashko, the refraction glossiness problem is still there with 3.10.02.
    I have added a scene file here. The only difference between the two figures is the one on the right has a lighter refraction color and translucency turned off. Otherwise this file is the same as the one posted by Svetlozar earlier on this thread.
    translucency01 - file from Vray forum - rod added - refract gloss problem.zip
    • #32
      There are overlapping triangles in the scene (there is a plane that is exactly aligned to a VRayLight). Not sure why Svetlozar set the scene up this way; it's best to avoid overlapping faces.
      That plane was used as a reference geometry in Maya since Lights are not transferable and I wanted to have identical scene on both platforms Max and Maya.
      It seems I have forgotten to remove it - I'll fix that and I'll update the attached scene.
      • #33
        [ATTACH]22168[/ATTACH]
        Thank you for the file. It looks like a bug to me, but I have to discuss it first with our developers before sending a bug report.
        The refraction IOR is somehow changed when the Glossy value is below 1 and Translucency is set to Hard model. For the other two models (soft and Hybrid) it works different.
        Tashko Zashev | chaos.com
        • #34
          it would be great to have Svetlozar's explanation of translucency added to the chaosgroup help site, would that be possible?
          (partly so i dont have to search for this thread every time i get stuck with translucency!)
          www.peterguthrie.net
          www.peterguthrie.net/blog/
          www.pg-skies.net/
          • #35
            I think this is possible. Let me check first and I will get back to you later.
            Update: Yes, we'll do it.
            • #36
              It's sort of reassuring that even the legends of this industry get stuck once in a while.... keep up the amazing work.
              • #37
                me?? I'm on this forum every 5 minutes trying to remember how to do stuff!
                www.pg-skies.net/
                • #38
                  Quick question... how does the Light Multiplier work? I've had it everywhere from 0 to 100000 and nothing seems to change. Just curious.
                  Thanks,
                  -Neal
                  Jim Lammers
                  Trinity Animation, Inc.
                  www.trinity3d.com
                  • #39
                    Works as expected on the sample scenes attached into my previous posts:
ID:	855390Click image for larger version
                    Would it be possible to send us the scene for investigation?
                    • #40
                      Originally posted by svetlozar.draganov View Post
                      Also please hold in mind to use only gray scaled colors for Reflection and Fog colors - otherwise the result won't be expected.
                      I guess you meant: "Refraction and Fog Colors"...
                      __________________________________________
                      www.strob.net
                      Explosion & smoke I did with PhoenixFD
                      Little Antman
                      See Iron Baby and other of my models on Turbosquid!
                      Some RnD involving PhoenixFD
                      • #41
                        Yes, exactly.
                        • #42
                          Hi Svetlozar,
                          Thanks for the explanation , my reply arrives late.
                          Will you be able to easily reproduce the same conditions under the LWF? I see you're not using gamma correction and the sRGB button.
                          Personally I find easier to see translucency effects / light falloffs in a gamma 1 environment as you seems to be working.
                          The challenge comes from the fact that you're in a very high contrast situation that makes translucency easy to see. Black environment, 1 single light, gamma 1 and a refraction value of just 10 out of 256.
                          Will the effect be so obvious in a normal environment with linear workflow and GI bouncing around the subject as if it was in a lit room?
                          Regards,
                          Giacomo.
                          • #43
                            If you could provide a sample scene with the described setup I may try to make it work.
                            • #44
                              This would be a good thread to have pinned. Great info Svetlozar!
                              • #45
                                Thanks for the nice words
