3D Displacement
  • 3D Displacement
    What causes this? I need my corners to cleanup, so I need 3D Displacement. I welded all the corners, and in this screen grab, I tried a shell modifier.
ID:	879351Click image for larger version
ID:	879352Click image for larger version
    2D Displacement works just fine.
    Bobby Parker
    www.bobby-parker.com
    e-mail: info@bobby-parker.com
    phone: 2188206812
    My current hardware setup:
    • Ryzen 9 5900x CPU
    • 128gb Vengeance RGB Pro RAM
    • NVIDIA GeForce RTX 4090
    • ​Windows 11 Pro
    model in quads and this will never happen. Maybe adding a subdivide modifier will help in the meantime, but you may still get some minor issues
      a subdivide modifier did help. I tried a quadmode, which didn't work, but a subdivmod did. Thanks!
      Bobby Parker
      phone: 2188206812
      • Ryzen 9 5900x CPU
      • ​Windows 11 Pro
        Quadmode wont work, you have to actually model in quads from the start. Vertices connected, 4 sided polygons, no holes only connected from one corner etc.
          I modeled it again, this time with quads, and it still doesn't work. If you want to take a look, here is the file.
          http://www.sendspace.com/folder/klic12
          Bobby Parker
          phone: 2188206812
          • Ryzen 9 5900x CPU
          • ​Windows 11 Pro
            Did you see this:
            http://forums.chaosgroup.com/showthr...D-displacement
            it should address your issue.
            Dmitry Vinnik
            Silhouette Images Inc.
            ShowReel:
              okay, that helped. I laid the walls down flat and used the populate terrain script, which did it.
              Bobby Parker
              phone: 2188206812
              • Ryzen 9 5900x CPU
              • ​Windows 11 Pro
                I worked the displacement out, thanks to you guys, but I am getting a strange light leak around the corner. Anyway, here it is.
ID:	851202Click image for larger version
ID:	851203Click image for larger version
                Bobby Parker
                phone: 2188206812
                • Ryzen 9 5900x CPU
                • ​Windows 11 Pro
                  retrace thresh on? geo shelled?
                  Dmitry Vinnik
                  ShowReel:
                    it's not shelled and I am not sure if I had retraced thresh on. I typically don't turn it on unless I get light leaks. This, to me, wasn't really a light leak. You can't really see it in these images, unless you zoom in, so I am probably good.
                    Bobby Parker
                    phone: 2188206812
                    • Ryzen 9 5900x CPU
                    • ​Windows 11 Pro
                      yeah looks a bit weird, almost like low subdivision in displacement. Your vegetation also cg?
                      Dmitry Vinnik
                      ShowReel:
                        Yes. everything is CG. I have things subdivided pretty good, but I can try to push it some more
                        Bobby Parker
                        phone: 2188206812
                        • Ryzen 9 5900x CPU
                        • ​Windows 11 Pro
