Been using Vray toon a bit lately and had a couple unexpected problems. This is a test render with normal settings. This is Vray 3.00.02 and Max 2014.
First is when using Object Visibility, I was hoping it would either leave the ink black and fade the object, or fade the object and the ink by the same amount. Instead, this happened.
Another issue I encountered was using the new Vray Clipper object. The problem here is simply that the Vray Toon ink doesn't seem to respect the clipper.
