Closing the VFB takes forever - why ?
  • Closing the VFB takes forever - why ?
    It happened in 2.4.x and now in 3.x - In the beginning everything is great but now everytime I close the VFB - it may take between 10-30 seconds !
    Why ?
    Is there a cache that can be deleted ?
    Regards
    NIR
    Max Design 2014 Vray 3.00.07 Win7 64
    3ds Max 2016/2021 (Vray 6.x), Windows 10 64bit , AMD 2990WX ThreadRipper 32/64 Cores, 128 gigs RAM , 2X RTX3090 48GB RAM
    Are you using the Nitrous viewport?
      Yes
      Shouldn't it be working with it ?
      Nir
        I have also found that the VFB can get very slow after renders finish, when you go to clear the buffer and when you want to close the VFB. I hope you might be able to speed these processes up if possible. I'm also using Nitrous. 2014.
        Alex York
        Founder of Atelier York - Bespoke Architectural Visualisation
        www.atelieryork.co.uk
          Try to disable "Improve Quality Progressively" under Display Performance of Viewport Properties.
            Thanks - will try this.
            Alex York
              Me too
              Nir
                OK
                I tried it but it does not help - Actually it took a bit longer this time
                Nir
                  Ok; I'm working on some code that handles the VFB UI differently; it's still experimental, but it might help for such cases and hopefully will go into one of the next updates.
                    Great stuff!
                    Alex York
                      Nir
                        Sweeeeeeeeeeeeeeeeeeeet, Vlado is #1
                        Brendan Coyle | www.brendancoyle.com
                          Hehe, we'll see. The way this experimental stuff is now, the 3ds Max UI remains active during rendering, which, while maybe useful occasionally, may also lead to unexpected problems, f.e. if you change a material during a render or go to File > Reset...
                            You mean that we can continue to work on the scene, tweak materials and other settings while rendering? This will be extremely beneficial!
                            Alex York
                              Nonono. I mean that you can click on things that you shouldn't F.e. if you change a material, it will change how the rest of the render comes out (or crash, depending on exactly what you changed).
                              If you want to fire a render and continue working, simply use backburner, or make a script to fire a 3dsmaxcmd render.
