Render elements rawreflection and rawlighting creating white pixels around silhouette
  • #16
    Originally posted by joconnell View Post
    Ah okay - so it's kind of doing a sneaky divide on the way out and replacing the original raw ref file?
    Exactly.
    • #17
      Seems like an elegant route - I'd say compers will like it too as if gives them the options of a fast, plus based workflow and the full breakdown in every case.
      Shame the forum doesn't have a "thanks" function for quick replies too!
      • #18
        Ok
        That means we have to output them all in 3ds max but when we comp we use only rawlighting and diffuse filter (we don't use in comp the lighting pass that is just needed internally by vray 3). Is that correct?
        But that's exactly what I did for my current project and I still get white border around my lighting pass (and also a bit in ref pass and sometimes even specular).
        Also I noticed the white border is reduced when I interpret the alpha as a straight in after effects instead of the default premultiplied. but it's still there and it's there in some silhouette that are inside the alpha so I can't remvie them completely by tweaking the alpha.
        __________________________________________
        www.strob.net
        Explosion & smoke I did with PhoenixFD
        Little Antman
        See Iron Baby and other of my models on Turbosquid!
        Some RnD involving PhoenixFD
        • #19
          Yes.
          Then it would be best to get us an example scene to support@chaosgroup.com so that we can look at what's going on.
          • #20
            I sent the files.
            you can see the result of this scene here: first a the top, this is the comp in after effects witht that huge white border and then below is the beauty pass that look ok. The white is impossible to remove completely in comp cause there is some on the border of the sphere in front of another sphere that is not part of the alpha. Also in the corners of the alpha it's very hard to remove.
            My shader is very dark and it is a bit over expose to get this result. If I use a default grey shader it looks a bit overexposed. but stil I don't understand why the element don't give the same result as the beauty.
            The white is caused mostly by the rawlighting pass but also by the rawreflection.
            And here is the scene too if someone want to try. And there is inside my nice chocolate shader for free if you want it by the way.: http://www.phylacterecola.com/strob/...efPass_002.rar
            www.strob.net
            Little Antman
            • #21
              delete please
              www.strob.net
              Little Antman
              • #22
                Ok I am sorry cause I was able to fix this and there is no bug in vray with the raw elements!
                What I had to do is just make some fixes in my comp in after effects:
                I just had to make sure the following elements's alpha interpretations were set to "Ignore":
                VRayReflection Filter
                VRayRawReflection
                VRayDiffuseFilter
                In my case I didn't need to ignore the alpha for the VRayRawLighting but when I ignored it it gave the same result so may be better to ignore it too.
                then if you have a background to add under them it must be in the same precomp as your vray elements or you have to apply an alpha on top of your elements's precomp.
                www.strob.net
                Little Antman
                • #23
                  Thanks for the quick update.
                  Tashko Zashev | chaos.com
                  • #24
                    That was not the first time I use raw elements. I use them since a long time in fact. But in that case because my scene was a bit overexposed with a dark shader and because I have a lot of light coming from the back I could not fix the alpha by applying the beauty pass's alpha to my comp like I did usually. But it's good to know that I don't need to do this at all if I ignore those elements's alpha channel. I am even wondering if vray should output those without alpha?
                    www.strob.net
                    Little Antman
                    • #25
                      Can be done but it requires additional coding. The best solution for now is to ignore the alpha channel for reflections when importing them in AE.
                      • #26
                        Ok,
                        Also the corresponding needed elements for any raw elements should be added automatically when adding those raw elements to avoid user mistakes.
                        www.strob.net
                        Little Antman
                        • #27
                          We'll make a suggestion about that into our system.
                          • #28
                            Might work for just the raw elements, however not for the filters or the non-raw elements. Though I'd prefer if this wouldn't be automated, instead of that a warning in max, the docs, or both.
                            Rens Heeren
                            Generalist
                            WEBSITE - IMDB - LINKEDIN - OSL SHADERS
                            • #29
                              Yes it would be better with a warning question like: "do you want to add also those elements needed for proper rendering of this pass..." and a checkbox to stop asking for this session and remember the answer for subsequent actions.
                              www.strob.net
                              Little Antman
                              • #30
                                Thanks for the suggestion guys, I've just added them into the feature-request-details.
