Vray 3.10.01 - distributed rendering broken?
  • #16
    I am having the same issue. I upgraded the farm with SP3 to remedy one issue and it made another. Looks like there is no simple uninstaller for SP3 either. I contacted vray support and they've pointed me to sales for some reason. Hopefully whoever answers that can get me the patch even if it is temporary.
    -Joel E
    https://www.biglittlepictures.com
    • #17
      joelly3d
      You can go to your Windows Command Panel and uninstall EXT 2. Sp3 is also listed there under installed plugins. It took almost 2 hours to uninstall it on one of my slaves, but afterwards DR worked again.
      • #18
        Originally posted by rporter8555 View Post
        zeronove,
        So far I have only installed SP3. Have not tried Ext2 yet, which that installer first requires and includes SP3 to install.
        Check the autodesk readme for SP3 and Ext2 (link here). Notice the instructions that say 3ds Max will crash after uninstalling SP3 unless you also make changes to or delete
        Workspace1.se.ini. Don't know if or how this affected the slaves, but they are working now after uninstalling SP3.
        Ron
        ok
        till now SP3 seems not to be available as regular DL but only if you are under Subscription so I didn't know anything about it
        Alessandro
        • #19
          It's unfortunate timing as almost everyone is away for the holidays now; we will release a patch, but it will have to wait until the beginning of January. We can get you an update if you email us to support@chaosgroup.com or if all else fails, to me personally at vlado@chaosgroup.com
          I see,
          just to double check:
          is this issue related only with SP3? I mean 3.10.02 is working fine with SP2
          Alessandro
          • #20
            On my part I did not install max SP3 yet,
            And I just confirmed that DR is working with a scene but not working with another scene with "render host is not responding" errors for all slave.
            I sent you an email with the problematic scene stripped down to the simplest.
            __________________________________________
            www.strob.net
            Explosion & smoke I did with PhoenixFD
            Little Antman
            See Iron Baby and other of my models on Turbosquid!
            Some RnD involving PhoenixFD
            • #21
              Originally posted by zeronove View Post
              I see,
              Yes, if you are still on SP2 the DR should work fine.
              Tashko Zashev | chaos.com
              • #22
                Originally posted by jstrob View Post
                On my part I did not install max SP3 yet, And I just confirmed that DR is working with a scene but not working with another scene with "render host is not responding" errors for all slave. I sent you an email with the problematic scene stripped down to the simplest.
                Thanks; looking into it now.
                • #23
                  I see there is a 3.10.02 version available for download. Does this fix the distributed rendering issue?
                  • #24
                    Nope. We will upload an official build on the website after the holidays.
                    • #25
                      Hello,
                      Thank you for the scene, we just tested it with the stable nightly _25406 and works just fine.
                      First test was with SP2 and second with SP3, no problem with version 3.10.02.
                      Please download the nightly build and let us know if you still have issues.
                      Tsvetan Geshev
                      Chaos Group
                      • #26
                        ok thanks I'll do it now
                        www.strob.net
                        Little Antman
                        • #27
                          I installed the nightly build you told me and I still get the same error in this scene. Render hosts are not responding...
                          www.strob.net
                          Little Antman
                          • #28
                            Ok, will keep trying to reproduce it.
                            • #29
                              where do we get the nightly builds from ?
                              Win10.Ryzen1950X. 80GbRam. RTX3080.RTX2070.Sketchup 22.0.354.VRaySketchUp.6001. - NvidiaStudioDriver 527.37
                              • #30
                                I removed SP3 (not Ext2 - i had not installed that yet) from all my render nodes and now thank goodness they are working again with distributed rendering. As they are just render nodes i did not have to do anything apart from uninstall using windows uninstall. I'll reinstall SP3 as soon as the next patch is available
