Scene rendered in Max2016/VRay3.20.02 too bright
    Originally posted by tashko.zashev View Post
    For backward compatibility our V-Ray Physical camera is preserved in Max 2016. Therefore scenes created with Max version prior to 2016 will still render the same in 3DS Max 2016.
    The lighting difference of the original issue here is due to a bug in the V-Ray 3 SP1 (3.10) in the Probabilistic lights code.
    So if we are updating from 3.0 to 3.20.02 - we will not have issue with IES ? Though we never used Probabilistic lights.
    Available for remote work.
    My LinkedIn: https://www.linkedin.com/in/olegbudeanu/
      Yes, the issue is only for the SP1 - V-Ray 3.1
      Tashko Zashev | chaos.com
        We just moved from 3.10.03 to 3.20.02 and found the lighting got messed up with IES lights... so have rolled back to 3.10.03.
        Are further fixes coming? Or is this current project not going to render correctly in any VRAY versions from 3.2 onwards?
        What should we do?
          What should we do?
          If I understand correctly, if the scene has been created in 3.1 it will render incorrectly in any version.
          A.
          www.digitaltwins.be
            What should we do?
            Bug is not in 3.20.02 - it is in 3.10.03 - in earlier versions of VRay your project will render different as well. Looks like the only solution for you is to finish current projects in 3.10 and after that move to 3.2.
            We moved from 3.0 to 3.2 and got no issues.
            • #21
              Righto, sounds like we will just have to live with it.
              Thanks all for the help.
