Warning: Invalid geometric normal
  • Warning: Invalid geometric normal
    As of lately, I have been getting a lot of Normal warnings. This is a new one, but still references that 'normal' is the culprit.
    Bobby Parker
    www.bobby-parker.com
    e-mail: info@bobby-parker.com
    phone: 2188206812
    My current hardware setup:
    • Ryzen 9 5900x CPU
    • 128gb Vengeance RGB Pro RAM
    • NVIDIA GeForce RTX 4090 X2
    • ​Windows 11 Pro
    And, each time I stop the render, for whatever reason and start it back up, I get even more of the same warnings. It started with 2-3 and now it's up to 33, however, I have changed nothing in the scene, except for V-Ray render settings.
    Bobby Parker
    phone: 2188206812
    • Ryzen 9 5900x CPU
    • ​Windows 11 Pro
      unicode instance? is it like an asset with Cyrillic name that's messing up something? usually invalid normal can be produced by either a bump or bad geometry, some times if its incorrectly tessellated.
      Dmitry Vinnik
      Silhouette Images Inc.
      ShowReel:
        Hey Bobby
        I've had "ïnvalid normal" issues with imported Revit geometry - especially if you perform some kind of Boolean operation on them. Do you have any stuff like that in the scene?
          No, I don't think so. I built the model in MAX, however, I imported some iCube iTrees.
          Originally posted by Bruce Hart View Post
          Hey Bobby
          Bobby Parker
          phone: 2188206812
          • Ryzen 9 5900x CPU
          • ​Windows 11 Pro
            In most of the cases where this error appears the final render is not affected but it may lead to bigger render times.
            Would it be possible to send us that file? We have similar reports when Embree is enabled or Bitmap set to screen is assigned to the Bump slot.
            Tashko Zashev | chaos.com
              It's a large project, but I'll see what I can do to send it. Thanks.
              Bobby Parker
              phone: 2188206812
              • Ryzen 9 5900x CPU
              • ​Windows 11 Pro
                I had this on a couple of projects recently, all of them had imported stuff from other software (Sketchup, Revit). The Sketchup one I had would take about 10 minutes to get through all the warnings because there were 1.2 million of them. It still rendered fine, but my god it was tedious. Eventually tracked down the erroneous geometry to a monitor arm/stand in one model - never found the cause in the others.
                [Edit] I appreciate this doesn't help you. Just know you're not the only one!
                www.robertslimbrick.com
                  Mine is an exterior and the only thing I didn't model was the trees and bushes. I have used the same trees and bushes for a couple years and I am just now having the issue. The project is large, so it'll take me some time to zip it up and upload it.
                  Bobby Parker
                  phone: 2188206812
                  • Ryzen 9 5900x CPU
                  • ​Windows 11 Pro
                    It is definitely Evermotion bushes. I deleted them from my scene, because they were not working for me, and the error went away.
                    Bobby Parker
                    phone: 2188206812
                    • Ryzen 9 5900x CPU
                    • ​Windows 11 Pro
                      I spoke too soon, however, I think it is still Evermotion trees. I deleted the bushes, but not the trees, and when the rendering hits the trees, I get the error. I hoping it;s not slowing things up.
                      Bobby Parker
                      phone: 2188206812
                      • Ryzen 9 5900x CPU
                      • ​Windows 11 Pro
                        Thanks for the update Bobby.
                        You can send us one of this problematic models (scenes) to support at chaosgroup.com
                          I sent one yesterday.
                          Bobby Parker
                          phone: 2188206812
                          • Ryzen 9 5900x CPU
                          • ​Windows 11 Pro
                            How do I get to V-Ray Support? They game me an answer, however not that I need it, I can't find it.
                            Bobby Parker
                            phone: 2188206812
                            • Ryzen 9 5900x CPU
                            • ​Windows 11 Pro
                              I found it in my email. I use the displacement roof script, which is causing the warning. Here is support's answer.
                              Thank you for providing the scene. Apparently the issue is an incorrect geometry in the roof in combination with displacement. To fix that isolate the "shake roof" geometry, set a editable poly modifier for it, and select the geometry from attached Image1. On the back of this geometry move the selected in Image2 polygon down. Do that for both of the geometries. This should fix the warnings.
                              Bobby Parker
                              phone: 2188206812
                              • Ryzen 9 5900x CPU
                              • ​Windows 11 Pro
