light cache building for hours now
  • light cache building for hours now
    left a scene to render for about 3 hours and came back and light cache was stil building, tried to cancel and render again but same, anyone else having this issue with the newest version?
    Architectural and Product Visualization at MITVIZ
    http://www.mitviz.com/
    http://mitviz.blogspot.com/
    http://www.flickr.com/photos/shawnmitford/
    i7 5960@4 GHZm, 64 gigs Ram, Geforce gtx 970, Geforce RTX 2080 ti x2
    Not me, but BR+BF is my current favorites. I have had LC hang, but not recently.
    Bobby Parker
    www.bobby-parker.com
    e-mail: info@bobby-parker.com
    phone: 2188206812
    My current hardware setup:
    • Ryzen 9 5900x CPU
    • 128gb Vengeance RGB Pro RAM
    • NVIDIA GeForce RTX 4090 X2
    • ​Windows 11 Pro
      AHH, was just a simple thing as converting the scene twice with vray scene converter, first time seems it didnt work, closed the scene reopened and converted again and now it works ok
        Glad to hear the issue disappeared but keep us posted in case it happens again.
          will do, seems it may have been some blend material from the standard material
            Hello,
            Talking about standard 3dsmax Blend material, is it supposed to be handled / converted by VRay Scene Converter or not ? just to know if it's a potential bug here or not
            Thanks.
            Nicolas Caplat
            www.intangibles.fr
              Originally posted by NicoC View Post
              Hello,
              Thanks.
              it seems to have converted it on the second try i did of the scene after converting once, saving then re opening the scene and converting again, idk why or how but it worked that way.
                I had to troubleshoot a friend's scene last week. Once I hid a certain batch of proxied trees LC just zipped along. Tried override materials and different opacity options in the materials which didn't work so I believe it was either a bad proxy, or LC had difficulty with so many trees bunched very tightly together. Even when they were off camera it made LC hang.
                  Yes, V-Ray scene converter will convert the Blend material to VRayBlendMtl.
                  If you send us the scene we will have a look at it.
                    This could be an issue, indeed, or not, depending on what the dyn mem limit was set to.
                    Back in the days of little ram, that was the precise behaviour to expect, with a limited dyn mem pool.
                    Lele
                    emanuele.lecchi@chaos.com
                    Disclaimer:
                      We're using machines w/ 64gb of mem and I set the memory to 0...usually. Perhaps I overlooked it this time...
                      One quick question: is there a reason LC doesn't use 100% cpu even with adequate memory available?
                        It depends on your scene; if V-Ray needs to load textures or calculate displacement on the fly, then the light cache might not manage to fully load all cores; however once all these things are in memory, it should proceed at full speed.
                          Got it. Thanks
